Quote Originally Posted by Street Dreams CC View Post
it only requires what the vehicle requires. A remote start is basicly doing what you would be doing sitting in the car. But only difference is instead of going through the ignition switch it is going through a box with relays. You got 1-2 power wires each has 30a fuse to the remote start. So it can draw 60 amps or alittle more.
Remember it has to power your blower motor for your heater, your ignition, your second ignition to run other needed computers, your parking lights and crank your starter. So if you car needs 35a to run all that then yes it will need to draw that through the power wires. If it only needs 15a to run all that then thats what its going to draw.
Got it! Thanks!
I bought viper 5701. planning to install soon.
I'll make sure I get all heavy wires not done T tap.
Thanks again!
