Thread: 07 GP GT audio install questions
Results 1 to 3 of 3
  1. #1 07 GP GT audio install questions
    Mar 2014
    United States
    I have the Metra GMOS04 harness and a JCV double DIN I am putting in the wifes car. The OEM head unit work fine and I get the chime in the door with the key left in the ignition. There are steering wheel controls that will be forfeited.
    The issue I am having is no sound.
    I have connected all of the wires in the 16 pin harness (minus those mentioned below) per the instructions in the link below. This would be in pages 2 and 3. The wife does have the digital radio receiver in the drivers side of the truck and I am assuming the amp is under the rear windshield from what my Alldata says.
    All of the wires are being used and connected properly minus the Brown wire as there is no mute, minus the Blue/Pink wire as the headunit has no Nav and minus the Black/Yellow from the 24 pin harness for the OnStar Level Adjustment. I have taken a volt meter and verified 12+v from the head unit remote wire all the way up through the harness to the backside of the OEM radio harness where it changes color to violet. The head unit itself will turn on and seems to function fine. It is a new unit.
    http://www.metraonline.com/files/pro...MOS-04_web.pdf
    Here is a link to the wiring info for the headunit. See page 55 for quick reference.
    http://books.jvc.com/Download/729373276/B5A-0378-00.pdf
    When the new unit connected I do not get any chime from the key left in the ignition per page 5 from the Metra link and the pot is in the full CW position.
    Anyone have any idea?
  2. #2 Re: 07 GP GT audio install questions
    I break things. WarStryker13's Avatar
    Oct 2014
    Frederick, MD
    The chime is supposed to come from the harness, I believe. I can't remember if the 07 has the same colors in the factory harness, but if so I can help with tracing the possible problem. I've been behind the radio more than one should.
    04 GP GT2: Handling upgrades, go-slow parts, and an attitude. Totaled.
    87 Dodge Ram 50:​ Junkyard rescue, resurrection in progress.
  3. #3 Re: 07 GP GT audio install questions
    GTP Level Member simbah's Avatar
    Lala land
    On the GMOS-04 there is a gain adjustment and a volume control these are located on one end next to the connector and on the side of the device. I don't recall which one is which so you will have to play around andfind out. One controls volume of chimes and other controls output sound. That is all.
    'When someone shares something of value with you and you benefit from it, you have a moral obligation to share it with others
  1. Audio install
    By mthorn11 in forum Midwest
    Last Post: 02-23-2013, 12:50 AM
  2. Question about audio install! Crazy quote from audio shop?
    By dellumo97 in forum Audio, Security & Visual Electronics
    Last Post: 09-05-2012, 03:13 AM
  3. 2008 JVC Audio Install Help!
    By YellaGirl937 in forum Audio, Security & Visual Electronics
    Last Post: 06-25-2011, 02:07 PM
  4. Audio install help :)
    By Bluemagic in forum Audio, Security & Visual Electronics
    Last Post: 01-07-2011, 08:57 PM
  5. Changing my Audio Install
    By I800C0LLECT in forum Audio, Security & Visual Electronics
    Last Post: 11-04-2010, 06:14 PM
