Thread: Problem with cylinder 1 spark plug.. keeps going bad!
Results 1 to 5 of 5
Threaded View
jstevanus Problem with cylinder 1 spark... 07-22-2012, 10:52 AM
dsmuts Re: Problem with cylinder 1... 07-22-2012, 11:45 AM
Fivefingerdeathpunch Re: Problem with cylinder 1... 07-22-2012, 05:23 PM
Scottydoggs Re: Problem with cylinder 1... 07-22-2012, 05:46 PM
blueguy Re: Problem with cylinder 1... 07-23-2012, 09:52 PM
  1. #1 Problem with cylinder 1 spark plug.. keeps going bad!
    SE Level Member jstevanus's Avatar
    Feb 2010
    Michigan
    My first problem was a rough idle, got the cylinder 1 misfire code from Autozone, did my research here, and replaced the spark plug. The problem was solved. Then, less than a year later, I had the same problem, and solved it by replacing the plug again! Why does this keep happening? I've asked a few car guys I know, and they had no idea. Does anyone have a suggestion or three? Any help is greatly appreciated.
    Edit: I found a post HERE where they are blaming the oil consumption issue. They say oil in the cylinder is destroying the plug. I've read that GM now has a solution for the oil consumption issue, but how much is the fix? I have no warranty.
  1. which spark plug?
    By crazybrownklick in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-04-2012, 07:39 PM
  2. Spark plug gap?
    By 91z in forum General Tech Discussion
    Last Post: 04-20-2011, 08:28 PM
  3. fouled plug on #3 cylinder
    By Langdon in forum 3.1L V6 (LHO/LG8)
    Last Post: 12-06-2010, 06:34 AM
  4. Spark Plug/ head problem on a 02
    By cardinals1970 in forum General Tech Discussion
    Last Post: 09-29-2009, 06:15 AM
  5. spark plug problem
    By dr456931 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-21-2008, 11:28 PM
