I have an 06 GXP and have really left it stock for now - except a K&N intake. It has been running strong until now.
I did a bunch of maintenance to it as I am taking her on a long trip in a couple of weeks.
Here's what I did: Replaced the spark plugs (original stock ACDelco) and replaced with NGK 5IX gapped to .040. Dumped some DE grease into the boots. Also cleaned my K&N cone. Reset the ECM (battery removed).
It has thrown a code and haven't had time to read it yet.
Here is what it's doing: runs like *beep* at idle - quite rough - (I feel like I'm sitting in a top fuel car with an insane cam ). Once you get going down the road it's fine .... taking off from stop is rough until you get the revs up. Ok on the highway. Tranny is shifting later than before (but that could be me babying it).
Sounds like a vacuum leak or MAF and TB need a good cleaning. Or is it something else?
Any insight would be helpful. I will read the code and see what it tells me ....
Cheers
