Thread: ABS/TCS problems
Page 2 of 2 FirstFirst 12
Results 21 to 24 of 24
  1. #21 Re: ABS/TCS problems
    Nov 2019
    WI
    Could be the steering wheel position sensor. Try having it calibrated before replacing. The stability control gets data from the steering wheel sensor and the abs wheel speed sensors in order to maintain vehicle control. I would get the vehicle scanned first to check for codes. And also use a scan tool to get live data from the wheel speed sensors while the vehicle is in motion. Check to see if one of the sensors drops out when the wheel is turned.
  2. #22 Re: ABS/TCS problems
    GT Level Member Hurricane87's Avatar
    Jul 2016
    Brevard County, FL
    I'd bet on this. That sensor went out on my CTS and took the traction control with it. Why on God's green Earth the car needs to know the steering wheel position when it should know the wheel positions at all times, and that's what matters, I've no idea.
  3. #23 Re: ABS/TCS problems
    Nov 2019
    WI
    I just saw a video where the abs system went crazy when the wheel was turned. Turned out to be the steering wheel position sensor. He has a scan tool that could read data from the steering wheel sensor. Did you ever get it fixed?
  4. #24 Re: ABS/TCS problems
    Nov 2019
    WI
    The stability control uses data from the wheel speed sensors, the steering wheel position sensor and the yaw rate sensor usually located under the center console. In this way the abs module, the Transmission control module, and the engine control module, can modulate the brakes individually at each wheel and cut engine power in order for the driver to maintain control of the vehicle. For example, if the rear end of the car was skidding to the right and you were steering to the right and applying the brakes, the stability control system would sense this and cut engine power, modulate the abs on the right side of the vehicle. The system works well in the winter on icy roads.
  1. A/c problems
    By russ99 in forum Introductions/Noob Questions
    Last Post: 05-30-2013, 06:19 PM
  2. HID problems AGAIN
    By lilbear6889 in forum Visual/Body Modifications
    Last Post: 07-26-2010, 07:12 AM
  3. 3 last problems
    By indyal in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-22-2009, 06:14 AM
  4. HID Problems
    By That Guy in forum Visual/Body Modifications
    Last Post: 05-19-2009, 10:58 PM
  5. more problems...
    Last Post: 05-09-2009, 05:37 PM
