Thread: A/c problems
Results 1 to 9 of 9
  1. #1 A/c problems
    May 2013
    cape girardeau mo 63701
    If any tec can help me i would be greatfull
  2. #2 Re: A/c problems
    What's your problem and what are you driving? A little bit of info can go a long way.
  3. #3 Re: A/c problems
    May 2013
    I got a 2000 prix gt 3800. I have replaced the compressor, the lines that run from compressor to dryer (ac hose assembly) had it professional shop charged it and it is holding presser but wont blow cold and all ac lines under hood are hot instead of cool are cold
  4. #4 Re: A/c problems
    You have a clog somewhere. Could be orifice tube or condenser
  5. #5 Re: A/c problems
    GT Level Member Kilroy's Avatar
    Mar 2013
    Manitoba, Canada
    Could the hoses possibly be connected wrong?
  6. #6 Re: A/c problems
    Not likely
  7. #7 Re: A/c problems
    May 2013
    No it only fits one way
  8. #8 Re: A/c problems
    if you didnt change the orifice tube, that could be the problem.
    the fans are coming on with the a/c right? the radiator fans that is.
  9. #9 Re: A/c problems
    May 2013
    Yea the radiator fans r coming on . But the motor has been running about 215 and it usually runs around 180 ish. No water leaks I think that is thermostat. Would that make it no blow cold . I have also changed the flap that changes the air over . But I don't if the thermostat wouldmake it not blow cold or make all the lines under the hood r really hot. Meaning a/c lines.
  1. Abs problems
    By sammie in forum General Tech Discussion
    Last Post: 09-11-2012, 05:33 PM
  2. abs problems?
    By astros2900 in forum Brakes/Suspension/Chassis
    Last Post: 03-20-2011, 09:36 AM
  3. Problems with the GTP
    By DaL in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-26-2010, 02:21 PM
  4. Got some problems with my '04
    By 04gpking85 in forum General Tech Discussion
    Last Post: 05-24-2009, 02:50 PM
  5. NEW GUY NEW Problems!?
    By 06GPNA3800 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-08-2009, 11:43 PM
