Thread: Coolant leak at thermostat
Results 1 to 4 of 4
  1. #1 Coolant leak at thermostat
    Wichita
    Replaced the thermostat not too long ago and it started to leak. Took it apart, cleaned everything put it back together and it still leaked. Took it apart again cleaned it and used sealant. It's still leaking. Ya'all have any thoughts on this?
  2. #2 Re: Coolant leak at thermostat
    pretty sure the 04 up only use a O ring. the t stat also gets wrapped in a rubber ring. could add a gasket if your not using one. make sure both sides of the lim and housing are clean and smooth.
  3. #3 Re: Coolant leak at thermostat
    Wichita
    NVM you guys the problem was way simple. The lower radiator hose clamp, to the wp, was loose. 🤦
  4. #4 Re: Coolant leak at thermostat
    yup, that would be a kick in the nuts lol easy fix at least.
  1. Small coolant leak turned into a large coolant leak
    By DreamerGT in forum General Tech Discussion
    Last Post: 09-23-2016, 11:00 AM
  2. Changed coolant and Thermostat still very little heat 2008
    By veener79 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-07-2015, 12:11 PM
  3. coolant and thermostat
    By Classy Pontiac in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-27-2012, 10:00 AM
  4. P0128 engine coolant too low, stuck thermostat?
    By thegipper in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 02-28-2011, 12:32 PM
  5. Low Coolant Light...Thermostat?
    By Rather B Blown in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-23-2008, 12:03 PM
