Thread: Low boost issue not related to BBv help please
Results 1 to 13 of 13
  1. #1 Low boost issue not related to BBv help please
    May 2015
    Az
    I have a 99 gt that has been top swapped it's got a mild cam and a 3.2 pulley and a customs tune the issue I'm having is the car only makes 2.9 lbs of boost (religiously) at wot with about 3 k.r. The BBv has already been bypassed so I know it's not that a few questions I have are how do I test the boost actuator? Is there anything else that can limit boost? (Car hits 2.9 almost immediately at acceleration but stays there) Any help is appreciated, and I'm sorry if I'm missing any important info new to the Grand Prix community.
    Thank you
  2. #2 Re: Low boost issue not related to BBv help please
    GTP Level Member Impala131's Avatar
    Knoxville, TN
    Is it possible that your boost gauge is broken? That seems like a very odd reading.
    2003 Grand Prix GTP.... the journey begins again....
    E85 Self Tune with HPT, 80# Injectors, Gen V 3.4 pulley, SD Headers, AL605 Plugs
  3. #3 Re: Low boost issue not related to BBv help please
    May 2015
    Az
    It's an aerospace interceptor but that may be possible it's as if the guage is limited to 2.9 before anything under 2.9 it seems to function regularly
  4. #4 Re: Low boost issue not related to BBv help please
    Apr 2015
    Columbus, OH
    Does it feel like its lacking? When I went on first drive with mine the solenoid was limiting me to 3 lbs, and I could definitely tell. Does the bbv move when you throttle it by hand?
    Top Swapped 01 Imp
    VS (very small?) cam, SD Headers, 2.8" pulley, 29°, ported everything, E85, AEM water/meth, Deka 60's, HPT tuned
  5. #5 Re: Low boost issue not related to BBv help please
    May 2015
    Az
    It doesn't feel at all how it felt before but that's on the butt dunno. And yes the actuator moves when the car is reved. the plunger rests on th intake manifold while the car is off. The plunger is fully inserted at idle and when I rev it drops instantly about half of its full travel distance but comes right back up.
  6. #6 Re: Low boost issue not related to BBv help please
    Apr 2015
    Columbus, OH
    Quote Originally Posted by Smikey View Post
    "The plunger is fully inserted"... My mind=gutter.
    But yeah, dunno man. Maybe belt is slipping? Just bypass it closed so you are in boost all the time and test it? Never tried but it should work. Least you'll eliminate the BBV.
    Top Swapped 01 Imp
  7. #7 Re: Low boost issue not related to BBv help please
    May 2015
    Az
    how do you bypass it? is that the ziptie trick? i tryd that today with no change. at all zip tied open or closed i did notice it will spike to 3.2ish while the tranny is in between shifting not sure what that means
  8. #8 Re: Low boost issue not related to BBv help please
    GTP Level Member 99GT2dr's Avatar
    Cibolo, TX
    Are you scanning? Running a 2 bar map? Do you have a manual boost guage you could use to test?
    '11 Suburban LTZ
    '99 SSEi
    '99 GT
    '09 G8 GT
  9. #9 Re: Low boost issue not related to BBv help please
    May 2015
    Az
    This is what it has
  10. #10 Re: Low boost issue not related to BBv help please
    May 2015
    Az
    No I'm not scanning not at that point yet but looking into the process the car has a map wired in but I believe it's a 1 bar no markings on it except a 1k20 stamp? But it's small and square looks like a 1 bar map.
  11. #11 Re: Low boost issue not related to BBv help please
    Cibolo, TX
    Yeah that's a 1 bar map. I could be mistaken here, but the aeroforce reads off the PCM, and the PCM uses the MAP sensor to read boost, if you hook a mechanical boost guage up I bet you'll see a lot more.
    EDIT: Or, get a 2 bar map, and make the necessary pcm changes, and it'll show on the AF.
    '11 Suburban LTZ
    '99 SSEi
    '99 GT
    '09 G8 GT
  12. #12 Re: Low boost issue not related to BBv help please
    May 2015
    Az
    I do have one of these
    i will install later today, but the car does have a custom dyno tune, could it be a running issue or computer issue?
    Also purchasing a mechanical boost gauge today
    Thank you again for everybody that's helping me this far
  13. #13 Re: Low boost issue not related to BBv help please
    Cibolo, TX
    You can't just install the 2 bar, you have to go into your map folder and change the max kpa so the pcm will read the higher values.
    Edit: stick it on and see what happens actually, the pcm might be set up for the 2 bar, you'll know if it is or not when you compare the mechanical guage readings to what the AF says.
    '11 Suburban LTZ
    '99 SSEi
    '99 GT
    '09 G8 GT
  1. Can anyone diagnose a possibly tune related issue?
    By nitehawkjcb in forum PCM Tuning
    Last Post: 02-25-2015, 03:24 PM
  2. Odd issue.. Trans Related???
    By Iceman6669 in forum General Tech Discussion
    Last Post: 11-07-2014, 05:44 PM
  3. BBV/ boost issue
    By scottgs03 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-03-2013, 07:59 AM
  4. Fuel Related Issue??? Or not??
    By SilvrGrandPrixGT in forum General Tech Discussion
    Last Post: 12-05-2011, 06:52 PM
  5. Boost issue
    By ninnyGTP in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-03-2010, 02:13 AM
