Thread: Motor noise at half throttle
Results 1 to 20 of 27
  1. #1 Motor noise at half throttle
    Jul 2014
    Belfast, me
    Hey guys I have an 04 comp g and at half throttle to 1/4 throttle it has a almost "loud tapping" to "knocking" noise. Any idea to what I'm hearing guys. I mean it's not a low milage cAr it had 170k so I'm not looking for it to be quiet but noises like this scare me..
  2. #2 Re: Motor noise at half throttle
    Oil is full and newer?
    Lifter tap, exhaust tick come to mind first.
    Running 91+ octane fuel right?
  3. #3 Re: Motor noise at half throttle
    Jul 2014
    Belfast, me
    Always 91. always Castrol syntec 5w30. Only 500miles on oil change maybe exhaust..?
  4. #4 Re: Motor noise at half throttle
    I'd have to hear the sound/tone to even give a educated guess.
  5. #5 Motor noise at half throttle
    Take a video
    04 Comp G.
  6. #6 Re: Motor noise at half throttle
    GXP Level Member Grimsin's Avatar
    St Thomas Ontario
    I had a noise like you describe. Finally got under the car and it was a heat shield above the downpipe.. was just touching the downpipe. Ripped it off.
    Wonder if it was creating false kr now that i think about it..never know now lol.
  7. #7 Re: Motor noise at half throttle
    Jul 2014
    Belfast, me
    Will false knock or knock in general make the cel come on?? It's never had a cel for knock but I have a Cam pos code Could that cause it?
  8. #8 Re: Motor noise at half throttle
    Apr 2015
    Columbus, OH
    What code?
  9. #9 Re: Motor noise at half throttle
    Jul 2014
    Belfast, me
    I'll check and give the codes that come up. But I have a multiple misfire which I changed wires plugs and icm. Still have the misfire code and now after I changed the icm a few months later the cam pos code came up. Emission small leak code. Sensor 2 o2 code from the catless 3"dp.
  10. #10 Re: Motor noise at half throttle
    Jul 2014
    Belfast, me
    P0341, p0455,
    That's all for now
  11. #11 Re: Motor noise at half throttle
    http://www.obd-codes.com/p0341 cam sensor
    the 455 is a evap leak or purge solenoid. http://www.obd-codes.com/p0455
  12. #12 Re: Motor noise at half throttle
    Jul 2014
    Belfast, me
    Thanks.
  13. #13 Re: Motor noise at half throttle
    GT Level Member Xorbex's Avatar
    Canada
    I have a leak on my header exhaust that sounds like a tick/knock. Do you hear any pfff pfff pff noises at all under throttle? Mechanical ticking and exhaust ticking sound similar but if you listen good you can tell the difference. I unplugged my radiator fans and felt around the exhaust and felt it puffing.
    RIP August 2015 - (2005 Comp G // Custom HAI / S1X Cam / 105 Crow Springs / Mild Ported heads / 3.4 Pulley / SD Headers / Dynomax Catback / Overkill Tune / Comp cams pushrods / LS7 Lifters //)
  14. #14 Re: Motor noise at half throttle
    Jul 2014
    Belfast, me
    Good point I'll try that thanks man!!
  15. #15 Re: Motor noise at half throttle
    Jul 2014
    Belfast, me
    Started the car up this morning when the motor was cold and the noise I've been hearing is coming from the back valve cover sounds like a valve tap. Is this common with these motors?
  16. #16 Re: Motor noise at half throttle
    it could be a broken spring, or a lifter gone bad. only one way to find out, take the v/c off and check em out. you cn run the engine cover off for a bit to watch the rockers.
  17. #17 Re: Motor noise at half throttle
    Jul 2014
    Belfast, me
    K will do thsnkd
  18. #18 Re: Motor noise at half throttle
    Jul 2014
    Belfast, me
    Checked the oil yesterday for shots and gigs and my oil looked glittery. So issues... - loud tapping In rear of motor and glittery oil.
    Any ideas now guys?
  19. #19 Re: Motor noise at half throttle
    Topeka, KS
    Sounds like your motor is Fvcked to me! Better start callin some junkyards. You probably spun a bearing.
    Go to www.moradpartscomany.com and see what they have available.
    Or www.carpart.com
  20. #20 Re: Motor noise at half throttle
    SWPA
    Glittery oil is bad news.
    The best way to see if you have a problem without a complete teardown is to drain the oil and cut the oil filter open. If you find flecks of copper in the oil and filter you are on your way to joining the Spun Bearing Club.
  1. Screeching noise from motor after header install
    By nawarkk in forum General Tech Discussion
    Last Post: 07-21-2012, 07:35 PM
  2. P1689 Code & Runs Rough Over Half Throttle
    By SUPERCHARGED3800 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-06-2012, 04:27 PM
  3. Noise from blower motor when turning left
    By SnowDrift in forum General Tech Discussion
    Last Post: 01-04-2012, 02:56 PM
  4. 2005 GTP strange noise when reving the motor
    By starscream5000 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-24-2011, 06:53 PM
  5. Weird noise under full throttle
    By RegorHtims in forum General Tech Discussion
    Last Post: 11-11-2010, 12:52 PM
