Thread: LIM side coolant port modification / coolant block off
Results 1 to 11 of 11
  1. #1 Re: LIM side coolant port modification / coolant block off
    I like to block it. There's too many times I've seen a TB gasket blow etc and cause issues. No coolant..no issue.
  2. #2 Re: LIM side coolant port modification / coolant block off
    Mar 2015
    Connecticut
    AHA! Blocking it takes TWO potentially leaking gaskets out of the equation. I knew about the TB gasket but didn't even think about the coolant flowing through it.
  1. Overheating and coolant leaking at corner of the block & manifold
    By kidkev in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-20-2014, 12:47 PM
  2. Leaking Coolant from Front Driver side
    By mstrozier in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-28-2011, 11:15 AM
  3. coolant is still leaking around LIM at passenger side
    By regalls in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-27-2010, 10:11 PM
  4. s/c coolant block off
    By iluvbst in forum General Tech Discussion
    Last Post: 09-17-2010, 07:46 AM
  5. coolant leak on passenger side under car.
    By Teardrop in forum General Tech Discussion
    Last Post: 09-07-2010, 03:42 AM
