Thread: Leaking Coolant from Front Driver side
Results 1 to 6 of 6
  1. #1 Leaking Coolant from Front Driver side
    Sep 2011
    Nashville, TN
    This is on a 1997 Grand Prix GT. Has about 140k miles on it and I have no idea what service has been done to this car prior to me purchasing it as I have no service records on it =\
    I just noticed that it leaks but it's a slow leak and on the driver front side of the car. The engine back, intake manifold area all seems to be clear. And this is external as the coolant and the oil itself is still it's normal color.
    Any ideas what this could be? Hoses maybe or something else on that side I should look at?
  2. #2 Re: Leaking Coolant from Front Driver side
    Look closely at the radiator end cap for any wetness, look under the throttle body for any wetness. It should be there somewhere.
  3. #3 Re: Leaking Coolant from Front Driver side
    Check the radiator, the plastic likes to crack, and once it starts it only gets worse.
  4. #4 Re: Leaking Coolant from Front Driver side
    Sep 2011
    Nashville, TN
    Thanks, will take a look at the radiator in the morning to see if that's where it is coming from. I feel that may be it due to where it's leaking.
  5. #5 Re: Leaking Coolant from Front Driver side
    SE Level Member KZOO3800's Avatar
    Nov 2010
    Kalamazoo, MI
    I had the same problem, somehow I had coolant spraying from a plastic coolant elbow (alternator bracket area) and it reached corners of the engine bay I would never have expected. Check all coolant lines you can locate.
  6. #6 Re: Leaking Coolant from Front Driver side
    Sep 2011
    Nashville, TN
    Yup couple of things with the cooling system. First, the Radiator does need to be replaced. Has a small crack in the lower side and being plastic needs to be replaced. Fun And second, at some point I need to get the hoses replaced. A little too soft and one is leaking, very small and not an issue at present but at some point I need to get that work done as well.
  1. Front Driver Side "Clunk" Mystery. Any ideas?
    By nickbuol in forum Brakes/Suspension/Chassis
    Last Post: 05-10-2011, 03:41 PM
  2. coolant is still leaking around LIM at passenger side
    By regalls in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-27-2010, 10:11 PM
  3. Noise in Front Driver-Side Tire Well
    By PsychOut in forum General Tech Discussion
    Last Post: 09-05-2009, 08:43 PM
  4. Window Problem (Front Driver Side Window)
    By trogdor007 in forum General Tech Discussion
    Last Post: 06-03-2009, 09:22 PM
