Thread: How to removing mps hub
Results 1 to 8 of 8
  1. #1 How to removing mps hub
    Sep 2013
    Massachusetts north shore
    Has anybody found a way to remove the mps hub without buying the adapter or making a adapter
  2. #2 Re: How to removing mps hub
    GTP Level Member WhiteLightningGTP's Avatar
    Nov 2012
    Frankenmuth, MI
    I used a hydraulic press... but I also took the snout completely apart. I don't think theres another way to do it besides those two options
    2004 Comp G "The Panda"- low, e85, big brakes SOLD
    2002 Trans Am- 6 speed, bolt ons or something, it's slow.
    2006 Silverado- forged ls2, 4l80e, plate kit, also slow...
  3. #3 Re: How to removing mps hub
    Quote Originally Posted by WhiteLightningGTP View Post
    yeah the only tool you can use, its called a supercharger pulley puller, its not at your local parts store either. we got a guy here who sells then and rents them. same guy who makes IC's in the for sale section, its a sticky, so its always up top
  4. #4 Re: How to removing mps hub
    And you'll probably need this along with the puller
    http://shop.zzperformance.com/store/...val-Plate.aspx
    04 Comp G.
  5. #5 Re: How to removing mps hub
    Sep 2013
    No I have a intense puller it's the mps hub on my gen 3 that I need to swap on to my gen 5 I thought I heard of someone using a 7/8 or 1" wrench behind the hub to pull it off I can make a plate like intense or zzp but if zzp uses a aluminum plate to pull it off why would a 3.4 pulley not work or even mount the pulley on backwards so the pulley would no crack . I like the intense way because there is no chance to pull a thread or break a bolt
  6. #6 Re: How to removing mps hub
    May 2008
    Schuyler, NE
    I've used pulleys to pull them off before. But, it's probably not something you should do.
  7. #7 Re: How to removing mps hub
    Sep 2013
    Did you flip the pulley
  8. #8 Re: How to removing mps hub
    newbs..
    You need the right SC pulley puller to start off. Instead of buying ZZP's tool etc. Just take two of your largest wrenches 18mm/19mm and put them behind the mps to make it bigger. Use puller like normal.
  1. Removing A/C condensor without removing radiator?
    By 97AutoXVette in forum General Tech Discussion
    Last Post: 04-02-2014, 07:43 AM
  2. Removing bbv.
    By Bluemagic in forum General Tech Discussion
    Last Post: 06-04-2012, 08:23 AM
  3. How should i go about removing this?
    By IBurnCamaros in forum Detailing Tips and Tricks
    Last Post: 04-27-2011, 10:49 PM
  4. Removing supercharger
    By GTPkid in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-31-2010, 09:15 AM
  5. Removing Oil Pan
    By dhoeschen in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-06-2009, 04:27 PM
