No I have a intense puller it's the mps hub on my gen 3 that I need to swap on to my gen 5 I thought I heard of someone using a 7/8 or 1" wrench behind the hub to pull it off I can make a plate like intense or zzp but if zzp uses a aluminum plate to pull it off why would a 3.4 pulley not work or even mount the pulley on backwards so the pulley would no crack . I like the intense way because there is no chance to pull a thread or break a bolt
