Thread: Removing supercharger
Results 1 to 9 of 9
  1. #1 Removing supercharger
    Jul 2010
    Columbiaville, MI
    I just bought a 98 GTP and I have to change the coupler so I figured I would pull off the supercharger too. But I saw what appears to fuel lines over the supercharger but idk because iam new to GP's. Could someone please explain how to remove the supercharger properly? also i have another s/c gasket so iam set there. Thanks
  2. #2 Re: Removing supercharger
    Charles City, IA
    Take the 4 nuts off the corners of the fuel rail and pull it off. Then unbolt the supercharger.
    SMGPFC Two Nipple General
  3. #3 Re: Removing supercharger
    GT Level Member rolyat's Avatar
    OKC
    You'd be better off just removing the snout from the blower if you're just replacing the coupler.
    2000 GTP: autolite 104's, 180 t-stat, shift kit, open cone spectre, 1.9 rockers, polished TB, ported blower, SD headers, zzp mps/3.4 pulley, 42.5lbs injectors, Reptile tune
  4. #4 Re: Removing supercharger
    Jul 2010
    Columbiaville, MI
    last time i took off a fuel rail it was in an expedition, what a mess that was, gas everywhere.
  5. #5 Re: Removing supercharger
    fuel rail is easy if you've got those stupid little clips on the injectors.
    four bolts, pull up and set aside. Shouldn't leak at all.
  6. #6 Re: Removing supercharger
    GTX Level Member Rather B Blown's Avatar
    Dec 2008
    London, Ontario
    leave the injectors attached to the fuel rail and pull the whole thing out. And make sure you buy the 2 little yellow o-rings from gm too you will need those. If you are just changing the coupler, it is 1000 times easier to leave the s/c on the car and just take off the snout.
    Quote Originally Posted by Reptile
    It sounds like you accidentally stuffed a midget in the downpipe, and he's hammering out an SOS to get out.
  7. #7 Re: Removing supercharger
    The whole thing comes off so easily though.
    Just take it off and port the outlet of the blower while you're there.
  8. #8 Re: Removing supercharger
    Dec 2008
    London, Ontario
    if you do take the blower off, relieve fuel pressure at the rail first before anything
  9. #9 Re: Removing supercharger
    Pffft...relieve the fuel pressure. If you just yank the rails and move them to the side you'll be fine. You don't have to remove the rails from the lines...or the injectors from the rail for that matter...just set it off to the right on the diagonal brace...it'll move that far, trust me.
  1. Removing Supercharger Snout Oil
    By Toasty in forum How To Write-Ups/Tech Tips
    Last Post: 10-05-2012, 01:56 PM
  2. Supercharger coupling OR Supercharger belt tensioner?
    By 99gtxws6 in forum General Tech Discussion
    Last Post: 07-23-2010, 11:56 AM
  3. Will a 2001 Bonneville supercharger work on a 97 gtp?supercharger swap
    By Bunique7 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-10-2010, 08:39 PM
  4. Removing supercharger cover
    By gpbastard in forum General Tech Discussion
    Last Post: 04-21-2010, 07:31 PM
  5. Removing Oil Pan
    By dhoeschen in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-06-2009, 04:27 PM
