Autolite 606's, no help. if you are reallly easy on it the car will drive. But if you even think of dipping the throttle it bogs. I would pull my codes again, but I locked my keys to my Park Ave inside said Park Ave, along with the reader. I was checking an issue with this car (misfire#3 and a Crank sensor error) and happened to have both hoods open at lunch and started changing plugs.
The plugs that came out of the GTP were in great shape, so I put them in the PA since they were fouled for some reason. Went to try and start the PA and discovered that the keys were still in the ignition....
Jeff
