Changed the MAP sensor with a Wells brand. The car didn't like that at all. I got onto the feeder and rolled onto the gas ans it would not go past 0. Then the DIC displayed Traction Control off and Reduced engine power. The engine idled but not much else, then it shut off. Coasted into a parking lot and couldn't get it to start. I would hit the start position, the starter would turn for a time period then stop. Did this several times. I turned the car off checked under the hood and forgot to connect the PCV return. I reconnected it and tried several more times. It would crank, run and die within 3 seconds. Changed back to the weigh all MAP sensor and then it started up and drove off. While checking codes I came up with a MAF code but figure that's because of the missing hose. Drove to return the Map sensor and buy some copper 606's seemed down on power the whole way there and back.
I can't wait till that scanner gets here
Jeff
