Thread: Which timing chain?
Results 1 to 20 of 52
  1. #1 Re: wich timing chain?
    I live here. UR LOSN's Avatar
    Rockford, IL
    you have 2 options when it comes to it. I chose the second.....
    1. add 2 gaskets to the front cover..this will space it away from the oil pump plate.
    2. machine the oil pump plate and bolts down .002 to avoid contact with the chain.
    I was lucky enough to buy a machined plate from FlynGTP in chicago. he has a machine shop shave them down for him....
  2. #2 Re: wich timing chain?
    Quote Originally Posted by UR LOSN View Post
    machine the oil pump plate and bolts down .020 to avoid contact with the chain.
    its gotta be machined down 20 thousandths.
    the jp is a better chain compared to the rollmaster, a few less have broken or caused problems. i would just get the double roller to begin with since you will never have to crack open the front cover again for the pure fact that the tensioner is gone.
