Thread: Which timing chain?
Results 1 to 20 of 52
  1. #1 Re: Which timing chain?
    awww maaaann..so right now im -2* retarded or so? i dont care to take the front cover off, screw it.
  2. #2 Re: Which timing chain?
    SS-DD Level Member IndeedSS's Avatar
    St Louis MO
    -2* will give you better top end. Unless you need more low to mid power, you are better off. Plus travelling on the hiway you should get better mpg at -2*. I on the other hand have the XP and plenty of top end and would like more low to mid range power.
    04 Indy SS build #972 - Traded
    2010 Camaro SS LS3
  3. #3 Re: Which timing chain?
    SE Level Member newfie's Avatar
    Toronto, Canada
    I'm looking at getting the Rollmaster Double Chain, I am running the L67 with a Turbo, will this knock me out 2*, or can I adjust it when I tune?
    634whp 10.9@127mph '99 GTPT
    CT "lumpidy" Engine, Big Turbo, CT Trans, 3" Cut-out, Magnaflow's, AGX's, Eibach's, GMMP/BMR's, FBod Brakes, Xenon's, AE 077's, Kumho 711's
    http://www.cartuning.ca
  4. #4 Re: Which timing chain?
    St Louis MO
    Quote Originally Posted by newfie View Post
    At this point in time it appears if you install it straight up you will be retarding the timing by 2*. Yes you can adjust it to +2* at install. However, I'm not sure if this has been done yet. Trannyman is going to give it a go on my car.
    2010 Camaro SS LS3
