Thread: Which timing chain?
Page 1 of 3 123 LastLast
Results 1 to 20 of 52
  1. #1 Which timing chain?
    lapeer michigan
    so i have LS6 springs springs wich are 90# springs and a equal lift/duration cam.. .507 lift / 234 duration , do you think i will be ok with a new stock chain and tensioner or should i go to a double roller... im really leaning towards the stock setup as many have been fine with it with the VS and S1X cam so i should be fine...just wanted to get atleast a hanfull of opinons before i buy... thanx in advance............
  2. #2 Re: wich timing chain?
    I live here. UR LOSN's Avatar
    Rockford, IL
    you wont need a double unless you go with 130# springs or above.
    for your setup the stocker will work. but...the double is added protection....
  3. #3 Re: wich timing chain?
    Port Hope Ont,Canada
    I read some were when installing the double chain,
    you must also do some work on the inside cover
    were the chain will rub .....
    I'm sure someone that has done this will jump in to
    explain this better..
    John
    1998 GTP, U-Bend Delete,Hi-Flow Cat,No Res,SLP Headers,BRISK Plugs ,180 T-Stat, 3.4 pully
    2007 GM Show and shine August 10http://www.youtube.com/v/aRh91q1jRio&rel=1
    OQCGP Clubhttp://www.youtube.com/v/j_YHmgU9ehs&rel=1
  4. #4 Re: wich timing chain?
    Rockford, IL
    you have 2 options when it comes to it. I chose the second.....
    1. add 2 gaskets to the front cover..this will space it away from the oil pump plate.
    2. machine the oil pump plate and bolts down .002 to avoid contact with the chain.
    I was lucky enough to buy a machined plate from FlynGTP in chicago. he has a machine shop shave them down for him....
  5. #5 Re: wich timing chain?
    Quote Originally Posted by UR LOSN View Post
    machine the oil pump plate and bolts down .020 to avoid contact with the chain.
    its gotta be machined down 20 thousandths.
    the jp is a better chain compared to the rollmaster, a few less have broken or caused problems. i would just get the double roller to begin with since you will never have to crack open the front cover again for the pure fact that the tensioner is gone.
  6. #6 Re: Which timing chain?
    Oklahoma
    There also was a huge discussion on the other site about some issues with the double roller as well. I believe Rollmaster has a single chain replacement that might be a bit better than the OEM one, Im not sure.
  7. #7 Re: Which timing chain?
    lapeer michigan
    yea i read something bout the double streching??thats why i wanting to double check on runing just a new stock one..im know ill be fine i just wanted to get a hand full more opinions on it...thanx for the input so far...i know 90# wont be bad on the chain ive seen some guys run 105# on the stock so yea..
  8. #8 Re: Which timing chain?
    SS-DD Level Member IndeedSS's Avatar
    St Louis MO
    I chose the JP single roller, but if I had to do over I would have gone stock. Most of this is because of more recent discussions about the Rollmaster and JP wearing ridges in the tensioner versus the stock chain. The other thing brought to light in a thread here, is that the Rollmaster with the timing on 0 will retard the cam timing on an L67 as it was designed for and L36. It appears the JP is the same. I guess knowing this you could advance them 2* to compensate...fwiw this is from others who know what they're talking about, and not me.
    04 Indy SS build #972 - Traded
    2010 Camaro SS LS3
  9. #9 Re: Which timing chain?
    Rockford, IL
    sorry, I typed it too fast. you are rigth with the correction.
  10. #10 Re: Which timing chain?
    SE Level Member scooz14's Avatar
    West Bloomfield MI
    with the ls6 springs, i HIGHLY recommend a dual chain.
    final seat pressure is somewhere in the neighborhood of 130#, due to the fact that they are a progressive rate spring.
    if you want to stick with the stock timing chain, get a whole new set( i have a 2000 mile set if you want it) and stick with some 105#'s
    12.591@108.00 1.95 60'
    329.9hp 400.1tq
    http://www.mccgp.com/member_details.php?mid=95
  11. #11 Re: Which timing chain?
    Bastard Reptile's Avatar
    Kansas City, MO
    Quote Originally Posted by scooz14 View Post
    Actually, they're 90lbs closed and 294lbs open to be exact.
  12. #12 Re: Which timing chain?
    West Bloomfield MI
    Quote Originally Posted by Reptile View Post
    actually, you are wrong
    open in 90#
    they are a progressive rate. i know a lot of people do it.if you really want to stick to a stock timing set recommend,that , to get 105s. i really don't like the single roller , as they require a tensioner. the stock tensioner is not designed for that type of chain, and will wear out very fast.
    why would you upgrade to 1.7's. do you have a cam?? if you don't and are intent on going with 1.7's, just get new stock springs. more then enough for .1 change lol
    329.9hp 400.1tq
  13. #13 Re: Which timing chain?
    Kansas City, MO
    open in 90#
    No....I'm not wrong. It's pulled from GM's Alldata. They measure the spring pressure at the seat pressure when the valve is closed. You're right about the springs being progressive...but do you honestly think that 90lbs of pressure open will snap a valve shut at 6000 rpm?
    Every spring manufacturer measures their spring pressures at the specified installed height whatever it will be with the valve closed.
    Taken from ZZP for instance:
    For the 3800 there are a few choices of valve springs:
    Stock –tested at ~70# pounds seat pressure @ install height of 1.72
    LS1 –tested at ~70# seat pressure @ install height of 1.80
    LS6 blue –tested at ~90# seat pressure @ install height of 1.80
    LS6 yellow –tested at ~90# seat pressure @ install height of 1.80
    Comp 105 –tested at ~108# seat pressure @ install height of 1.80
    Comp 130 –tested at ~135# seat pressure @ install height of 1.80
    Comp dual spring-tested at ~135# seat pressure @ install height of 1.80
    Comp 150 -tested at 155# seat pressure @ install height of 1.90
    They all explain that they are tested at seat pressure, not open.
    I"m not trying to bust down on you....but I know what I'm talking about.
  14. #14 Re: Which timing chain? Update
    St Louis MO
    Yes, there is a timing difference between the L67 and L36, we forget the exact number of degrees. That's why the cam gears differ between the 2 - one has triangle hole and the other has round holes so the assembly line could easily tell them apart. I believe the L67 had the triangles, but it's been a long time since we've looked at one. You can simply compare the stock cam gears and determine the degrees of difference.
    We haven't kept up with what's available for the 3800 - what's the rollmaster and jp timing chain sets? Are they stronger or double roller or something?
    This is a reply to an email I sent to Thrasher, inquiring about the cam timing differences between the L36 and L67. Remember the guys that started up Thrasher were GM engineers.
    2010 Camaro SS LS3
  15. #15 Re: Which timing chain?
    SE Level Member newfie's Avatar
    Toronto, Canada
    I'm getting a double set-up also...just want something in there that will last longer than stock, and keep it's strength. I havn't heard anything about the double roller stretching?
    634whp 10.9@127mph '99 GTPT
    CT "lumpidy" Engine, Big Turbo, CT Trans, 3" Cut-out, Magnaflow's, AGX's, Eibach's, GMMP/BMR's, FBod Brakes, Xenon's, AE 077's, Kumho 711's
    http://www.cartuning.ca
  16. #16 Re: Which timing chain?
    a couple people have broken doubles with a lot of horsepower or it rubbing on the oil pump cover. stretching doesnt seem to be a problem that often either.
  17. #17 Re: Which timing chain?
    Toronto, Canada
    So will I have a problem when I do the upgraded cam and springs?
  18. #18 Re: Which timing chain?
    lapeer michigan
    when he says alot of horsepower im assuming 400whp+
  19. #19 Re: Which timing chain?
    Toronto, Canada
    Which I will be well above....that's why I'm worried now
  20. #20 Re: Which timing chain?
    lapeer michigan
    oh really , what you got goin on?!?!?!??!?!
