Thread: Top Swap having horrible idle, no power on throttle
Results 1 to 20 of 67
  1. #1 Re: Top Swap having horrible idle, no power on throttle
    missouri
    my top swap sounds exactly like yours in the video. I'll be watching this thread closely!
    just fired up my top swap last night so i havent had a chance to troubleshoot yet.
    update: swapped in my gt's mass air sensor and IAC, replaced some sketchy vacuum lines and for now...the idle is smooth and no longer sounds like the engine in your you tube video. now to fix the exhaust leaks.....
  2. #2 Re: Top Swap having horrible idle, no power on throttle
    May 2014
    New Mexico
    Well guys, here is an update.
    I fixed the exhaust leak and the vacuum leak to the best of my knowledge. that cleared up all engine codes except for the o2 sensor code. She was running much better but still had a rough idle, but drivable. Then two days ago, I started her up to take my girl and son to get some Panda express, not even 3 minutes on the road and i hear a LOUD cracking noise. Turns out I somehow sent 2 rods straight through the block. I wasn't even driving her hard. So, Now shes in the shop getting a new block and I'm $3100 poorer.
  3. #3 Re: Top Swap having horrible idle, no power on throttle
    Oct 2014
    portland oregon
    ugg im sorry bro thats hard news 3100 is a lot of money. I would cry. in case your not the type to cry ill cry for you
  4. #4 Re: Top Swap having horrible idle, no power on throttle
    May 2014
    New Mexico
    Quote Originally Posted by wowitsfast View Post
    I almost cried. lol
  1. Throttle CEL(s) No Power
    By Crocitto49 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-22-2013, 11:26 PM
  2. 2000 GT stall at idle and when let off throttle
    By burgundybullet in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-26-2013, 09:28 PM
  3. Throttle Body to vacuum line connector '99 Grand Prix (Also, erratic idle issue)
    By killswitch83 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-05-2012, 05:52 PM
  4. warm/hot start HIGH rev idle/ sticking throttle??
    By rschap1 in forum General Tech Discussion
    Last Post: 04-03-2012, 01:26 PM
  5. Throttle bounces at idle AND while driving
    By navillus in forum General Tech Discussion
    Last Post: 05-30-2010, 04:48 PM
