Thread: Top Swap having horrible idle, no power on throttle
Page 4 of 4 FirstFirst ... 234
Results 61 to 67 of 67
  1. #61 Re: Top Swap having horrible idle, no power on throttle
    GTP Level Member 99GT2dr's Avatar
    Cibolo, TX
    Ok, well it didn't "blow up", the oil was most likely contaminated causing it to spin a bearing or 2 (no evidence, just an educated guess). After topswapping my '97 GT, I drove it to PA from TX and back, fully loaded up with kids and crap. On the way back I even squeezed an L36 shortblock in the spare tire well I got from buck531 on the forums. Plenty of track passes, and I didn't drive it very easy daily, all on the 60E trans.
    Unsure of op's mechanical experience, but if it's done right there's absolutely no reason a top swapped L36 would be any less reliable than any other 3800.
    He also has a 1 year warranty on the motor he bought, so if anything happens again, he's covered. I personally would've either L67 swapped, or L67/HD swapped it when the other motor ate it. He may not have had the means to do it, though.
  2. #62 Re: Top Swap having horrible idle, no power on throttle
    May 2014
    New Mexico
    Quote Originally Posted by 99GT2dr View Post
    Just called the shop to confirm, they're putting in an L67 block not an l36. My mistake.. So I'll have an L67 with a GT trans. At least it has better gearing, i think. lol
  3. #63 Re: Top Swap having horrible idle, no power on throttle
    Cibolo, TX
    If you were local to me, we could've done the same thing for about $2500 less in a weekend, or in one day if my back could take it. The 3.29's are good for city driving, the 2.93's are better on the highway, though. I notice I can get a lot more into the throttle without spinning in the regal than I ever could in my GT. Also, are you getting back your old motor to sell parts off of (top end)? Or are they using an L67 short block, and installing the top end of your current engine? Figure you could at least make a few dollars back selling the heads, blower, etc.
  4. #64 Re: Top Swap having horrible idle, no power on throttle
    GXP Level Member Grimsin's Avatar
    St Thomas Ontario
    Quote Originally Posted by Runicdionysus View Post
    If you read the entire thread, you'd see that I wasn't flooring the car when it blew up. I was taking a regular drive to panda express. I floored in maybe once or twice when we were very first trying to diagnose whatever problem the engine was having.
    i Know you werent flooring it when it blew up, but flooring a car that has a poorly running engine and no way to scan it to see what it is doing isjust not good lol, the l67 should be a safer bet for you so thats good the shop is doing that, does reptile need to do a retune since its a l67?
    3.8l N/A POWA! :4'' HAI\L67 HVTB\HV3\ER Rockers\WP underdrive pulley\Headers\cat delete\91 octane overkill incar tune.3.69 gears, Trans go shift kit.
    My Car:http://www.grandprixforums.net/threa...2005-Impala-LS
  5. #65 Re: Top Swap having horrible idle, no power on throttle
    Bastard Reptile's Avatar
    Kansas City, MO
    Yeah, it'll probably need retuned eventually, the timing won't be optimal for the lowered compression.
    FWIW, most of the times when the engines let go like this, it's already been running hurt for a while. Could be a week, could be a month.
  6. #66 Re: Top Swap having horrible idle, no power on throttle
    May 2014
    New Mexico
    They using an L67 short block and the newer heads. I'm getting my heads back, might be able to sell them for something. I got them cleaned and cut right before the swap too.
  7. #67 Re: Top Swap having horrible idle, no power on throttle
    Cibolo, TX
    Sell locally if you can, they're heavy bastards to ship.
    '11 Suburban LTZ
    '99 SSEi
    '99 GT
    '09 G8 GT
  1. Throttle CEL(s) No Power
    By Crocitto49 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 12-22-2013, 11:26 PM
  2. 2000 GT stall at idle and when let off throttle
    By burgundybullet in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 01-26-2013, 09:28 PM
  3. Throttle Body to vacuum line connector '99 Grand Prix (Also, erratic idle issue)
    By killswitch83 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-05-2012, 05:52 PM
  4. warm/hot start HIGH rev idle/ sticking throttle??
    By rschap1 in forum General Tech Discussion
    Last Post: 04-03-2012, 01:26 PM
  5. Throttle bounces at idle AND while driving
    By navillus in forum General Tech Discussion
    Last Post: 05-30-2010, 04:48 PM
