Thread: Help with Rod Replacement... yes I searched.
Page 4 of 5 FirstFirst ... 2345 LastLast
Results 61 to 80 of 84
  1. #61 Re: Help with Rod Replacement... yes I searched.
    Enfield, CT
  2. #62 Re: Help with Rod Replacement... yes I searched.
    page 4 lol
    what a waste of time this thread is.
  3. #63 Re: Help with Rod Replacement... yes I searched.
    Enfield, CT
    Yea they are gonna clean it up 2morrow. Too much hostility.
  4. #64 Re: Help with Rod Replacement... yes I searched.
    May 2008
    Schuyler, NE
    I had a L67 rebuilt by a run-of-the-mill machine shop after spinning a bearing. It ran 30k miles after without issue before it was yanked out for a different build. I sold it about a year ago to a guy that dropped it in his Impala to daily drive. No issues again.
    These motors can be rebuilt, and they are. The bottom ends can be pulled apart and re-assabled. People have done them in the past without issue, and you will continue to see more of that, as the prices of these motors continue to rise. IDK about you guys, but I can't find a L67 in the junkyard for less than $700, unless it has a ton of miles on it.
    Lots of these have been built over the years without problems. Believe it or not, rebuilding a SBC correctly and within tolerances is not much different than rebuilding a series II or III 3800 correctly. It's just not seen much because most of the members have moved on. And, since a bone stock L67 will hold more power than 99.9999% of people on here will ever make, it was, and still might be cheaper just to pony up and get a junkyard unit.
  5. #65 Re: Help with Rod Replacement... yes I searched.
    May 2008
    Schuyler, NE
    Once I run out of cheap L67 motors, or make enough power to legitly break one, I will be building one.
  6. #66 Re: Help with Rod Replacement... yes I searched.
    May 2012
    Where winter never ends
    Idk, we still got em here for round 150-300 for a 100k mile motor.
    Never said they can't be rebuilt, they can. It still just a pushrod V6. I just takes way to much effort to make it worth it. Its smarter to just go to the JY and get one.
    2000 Regal - Winter Beater
  7. #67 Re: Help with Rod Replacement... yes I searched.
    Enfield, CT
    Quote Originally Posted by ADecker View Post
    This is true
  8. #68 Re: Help with Rod Replacement... yes I searched.
    May 2008
    Schuyler, NE
    I just searched on carpart around Sioux falls, and the prices are nowhere close to that. Nor the miles.
    You guys pretty much said, if you attempt to rebuild a 3800, it won't last. Don't make me go back and quote all of it.
  9. #69 Re: Help with Rod Replacement... yes I searched.
    Enfield, CT
    you can rebuild a 3800 but the cost to do it correctly outweighs a JY motor. At least around here it does.
  10. #70 Re: Help with Rod Replacement... yes I searched.
    SE Level Member nukkinfuttz's Avatar
    Sep 2012
    Richmond Va
    Dude, this isn't paint. This is us trying to save you some money!
    An opinion which is based on no factual data about my situation... maybe you don't know that engines from car-part.com in.my area are between 700-1200. I'm not going to get one from a pick n pull because they don't know the condition of them and there is a chance its in the junk yard for a bad motor. Then what have I accomplished besides waste hours of my life for not? So I could spend 50 more dollars to buy a replacement rod, or spend 700-1200 more for a known good engine. That's not saving me money. That's just your perception based off of assumptions.
    91BerettaGTZTurbo=Holset HX-35,26PSI,Bored,EagleRods,WisecoPistons,O-rigned,TitanCopperHG, adj Cam Gears,Custom turbo mani,TurboSmart36mmWG,Screamer Pipe,Custom 3"turboback,MSII-E, LC1Wideband, PyroMeter,KnockSense,Walbro 255LPH,75lbs/hr inj's,3"Core42"Wx15"T IC,HKS BOV Waterinjection,antilag,6puckClutch,Slicks, just needed a Part Number
  11. #71 Re: Help with Rod Replacement... yes I searched.
    Dec 2012
    Where 4T65E's were born
    Let's just agree here, there is one fact that we know is true and you don't, and that's the whole reason this thread is going on and on... That slapping in a rod and bearing is not likely to last much longer than 500 miles. You say yeah right it will last a long time. We say no, not likely. You're a pretty stubborn person to not agree with like 10 people, many of which have been around these motors a lot longer than you. We are not experts at throwing rods in 3800s because we're smarter than that.
    But we're on the same page now man.. Go for it.
    Sold.
  12. #72 Re: Help with Rod Replacement... yes I searched.
    Sep 2012
    Richmond Va
    Quote Originally Posted by Jerseydoggs View Post
    dude. just leave, dont let the door hit you in the ass. you will never fit in here. or anywhere else for that matter with your attitude.
    you cant find the part cause you cant buy it any more, back from page one of this crap fest of a thread. have fun up on your high horse all alone in life.
    I see no reason to leave just because you caught a case of butthurt. I.just wonder how the guy who is throwing a temper tantrum because I won't change what IM doing because he said so is then saying I am on a high horse.... sounds like you are the one that knows best according to you,sir, when you don't know anything about my level of experience, tools, past projects or access to machine tools.
    Nor do I care if you think I will fit in with your crew of "you can't do that" vaginas that are scared to build a motor. Just because it didn't work for someone else doesn't mean it won't work.for me.
  13. #73 Re: Help with Rod Replacement... yes I searched.
    Sep 2012
    Richmond Va
    page 4 lol
    Which is mainly due to you and your cohorts repeated attempts at changing the subject to what I should do, and then insulting me because I won't do as you say simply because you say...
  14. #74 Re: Help with Rod Replacement... yes I searched.
    May 2012
    yeah the JY is expensive but everyone here goes through a local guy.. He has 3800s for 100-500 bucks..... lol Not disagreeing here man just saying. and it wont last if a rebuild isn't properly done
  15. #75 Re: Help with Rod Replacement... yes I searched.
    Sep 2012
    Richmond Va
    I'm doing a lot more than slapping a rod and bearing in it.... but again we have a reply to what I should do without knowing all the facts. I shouldn't need to explain my whole process to you in order to ask for a rod part number... nor do.i need your approval to proceed with my rebuild. Why am i the asshole for calling you out on sticking yiur nose into.my business wjere it doesnt belong? I just needed a part number. If you cared to kmow the facts, you could certainly ask, but to cast judgement about my actions without knowing the full set of facts makes you look like a retard.
  16. #76 Re: Help with Rod Replacement... yes I searched.
    May 2008
    Schuyler, NE
    I watch craigslist and the local forums to try and pick up running l67's for way cheaper than the junkyard has them. But, they are so much harder to find than they were 3-4 years ago. Eventually, we will have to build them if we want an L67.
  17. #77 Re: Help with Rod Replacement... yes I searched.
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    If you would have stated that when they were giving advice then this all wouldn't have happened......
    2012 F150 STX
    - Gonna be a race truck
  18. #78 Re: Help with Rod Replacement... yes I searched.
    Sep 2012
    Richmond Va
    Lol, so now your justification is the assumption I will not do it properly... thanks
  19. #79 Re: Help with Rod Replacement... yes I searched.
    Sep 2012
    Richmond Va
    Agreed, I have been checking CL weekly hoping for a wrecked car or spare engine to.come up. I know I'll get it cheap that way, but no luck for quite some time now.
  20. #80 Re: Help with Rod Replacement... yes I searched.
    May 2012
    Quote Originally Posted by nukkinfuttz View Post
    With proper machining and machine shop work it can be done. Dude, you are the biggest ass I have ever met. We are all telling you its possible, if not done right it will go pop. Its smarter/ cheaper to just buy a JY motor.
  1. Ok...searched high and low with no results, so here it is:
    By NCBikerBoy in forum General Tech Discussion
    Last Post: 07-08-2013, 06:10 PM
  2. CAI-Already searched the forums
    By Bkindhart in forum 04+ Specifics
    Last Post: 04-24-2013, 09:13 PM
  3. 3.29 Question, and i searched a LOT
    By steves86ta in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-12-2012, 12:45 PM
  4. HEADER Q''S (searched for but no luck)
    By speed demon in forum General Tech Discussion
    Last Post: 06-14-2012, 12:28 PM
  5. A/C Troubles, I'm all searched out.
    By JESSEGOTTA GP GT in forum General Tech Discussion
    Last Post: 04-17-2010, 04:58 PM
