Thread: heads and cam install
Results 21 to 40 of 43
  1. #21 Re: heads and cam install
    please re read item #1 from post #10 lol
  2. #22 Re: heads and cam install
    Leaning over the fenders for a couple hours scraping headgaskets and cleaning bolt holes is pretty hard on the knees and back.
    Yalps
  3. #23 Re: heads and cam install
    The Boss Iceman6669's Avatar
    Jun 2011
    Meh to each their own I guess. I really had no issues with the motor still in the car. If/when I do it again I'll prolly do it that way again.
    2011 F-150 Yote powered
  4. #24 Re: heads and cam install
    Maybe your extra padding helps?
    trollololol
  5. #25 Re: heads and cam install
    Jun 2011
    Quote Originally Posted by blueguy View Post
    trollololol
    Could be the case I guess. If so. Fat guy 1 skinny guy 0
  6. #26 Re: heads and cam install
    Buffalo
    Meh... Sometimes you just gotta do what you gotta do to get going again
    Not everyone has the room pull a motor, or owns a picker or has the time
  7. #27 Re: heads and cam install
    Quote Originally Posted by Iceman6669 View Post
    But I can stand in the engine bay.
    With the engine still in the bay.
    I guess that's a plus.
    Fat guy 1, Skinny guy 1
    Seems we are evenly matched, good sir.
  8. #28 heads and cam install
    Quote Originally Posted by crazyguy03 View Post
    This!
    I did mine through the cradle didn't have access to a hoist at the time and didn't have room in the garage if I didn't finish it that day. Out the stands up high enough and you don't have to worry about kiing your back to much.
    04 Comp G.
  9. #29 Re: heads and cam install
    hangover park IL
    considering that ive found you have a high chance at your rear cover gasket leaking coolant into your oil...and that you cant repair it or even find out there's an issue till ya pull the motor....means i pull the motor EVERY time.
    so far im up to nearly 75% of the engines leaking coolant or oil from that cover.
    take yer chances or not...i sure dont
    edit, this is an 04 motor with 75k
    ~James~ Psychotic Gearhead
  10. #30 Re: heads and cam install
    Last motor we pulled had nearly 200k on it.
    There was hardly even a gasket left.
  11. #31 Re: heads and cam install
    Hmm never knew about this think that a prime cause for all the spun bearings on the rotating assembly?
  12. #32 Re: heads and cam install
    hangover park IL
    its been the issue for almost every car ive had with a "mysterious, non findable coolant leak"
    but i put it up there with the "you might as well do it when you do a cam/oilpan gasket/head or LIM job.
    basically if your lim gaskets arent the killer, that rear cover likely is
    this is an 06 with the alum rear gasket (sucks) that had 50-60k on it
    ~75k 05
  13. #33 Re: heads and cam install
    hangover park IL
  14. #34 Re: heads and cam install
    damn glad you and bill boost tend to document the hell out of things thanks!!
    noted for future 3800 projects.
  15. #35 Re: heads and cam install
    hangover park IL
    a true mechanic doesnt just repair the symptom, he finds and fixes the root cause.
  16. #36 Re: heads and cam install
    right I don't like to half ass either unless its time essential to get it back on the road or some other circumstance.
    Other wise I 100% agree if its not fixing the actual cause its just a ticking time bomb. (then again aren't all modded setups?)
  17. #37 Re: heads and cam install
    Kemmerer, Wyoming
    that picture dosent really mean anything to me, but if you say the gaskets are bad then I will take your word for it. I will pull the engine and have all the gaskets redone. I had an oil leak earlier, it was coming from the oil sending unit and the oil pan was also leaking. I replaced the sending unit and thought the leak was fixed, but it is still leaking, not as much as before but enough that I can still smell it burning, I'm sure its from the oil hitting the exhaust downpipe.
  18. #38 Re: heads and cam install
    Buffalo
    So what gaskets do you recommend if the metal ones are ****?
    i need to re-gasket this whole motor I have out right now , it's an 08 l26 never used
    thanks
  19. #39 Re: heads and cam install
    hangover park IL
    felpro cs9917 (-1-2-3 suffix whatever) is the crank set and it sells for less than the damn oil pan by itself (it comes with the pan gasket)
    you just use the paper rear gasket with the cover. the paper also makes it easier to do the JB weld balance shaft oiling delete while your there.
    i coat the paper gasket with permatex aviation sealer.
    keep the rolocs in your toolbox and buy a box of razor blades and a good holder.
    remove cover, wipe around main oil galleys with brake cleaner soaked rag, blue tape discs placed over to keep **** out of the passages while you curse the gasket for the next 10 minutes,clean em last and always push away from the hole...if anything falls in it'll be right at the edge and you use yer pinky or a lint free towel to wipe it out before final surface cleaning with solvent soaked towels.
    once its clean and the towels come away clean i use blue tape to pull the fuzz off the important area's and put it together.
    that link has alot of my crap that ive repeated constantly over the years
  20. #40 Re: heads and cam install
    Buffalo
    Perfect thank you. I was wondering what to do with the balancer since it won't be used with the double roller
  1. Help on crack heads..need advice on l26 heads
    By crazybrownklick in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 07-25-2013, 10:07 AM
  2. ZZP Heads VS Intense Heads
    By PurpleGuy in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-13-2011, 07:57 AM
  3. Intense's S3 Heads VS. ZZP's S3 Heads.
    By pontiackid in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-15-2009, 02:08 PM
