Thread: Coolant Leak - LIM? :(
Results 1 to 8 of 8
  1. #1 Coolant Leak - LIM? :(
    SE Level Member mckillin's Avatar
    Ontario, Canada
    Hey guys
    2004 Pontiac Grand Prix GTP 193km
    After 6 years of ownership the gasket has finally gave out... I'm on holidays for the next week so planning on attacking this job.
    Just wondering how far I should go?
    I'm planning upper/lower gasket and valve covers as they look alittle wet. Anything I'm missing I should do while its apart?
    Would you agree felpro is a good way to go? It is 2nd generation with aluminum seals
    Thanks in advance
  2. #2 Re: Coolant Leak - LIM? :(
    GTP Level Member 231FUN's Avatar
    Dec 2011
    Ontario,Canada
    Fel pro are fine as long as they are the aluminum or steel replacement LIM gaskets.
    I'd buy a set of the new aluminum coolant elbows to replace the plastic ones too while your at it.
    If you're going to do VC gaskets aswell get new grommets for the bolt holes with the gaskets.
  3. #3 Re: Coolant Leak - LIM? :(
    Ontario, Canada
    thanks i already did the aluminum elbows last year so that should be good
  4. #4 Re: Coolant Leak - LIM? :(
    Pennsylvania, USA
    Make sure to use some thread sealant on the LIM bolts when reinstalling. Maybe replace the injector o-rings as well since you'll be pulling the fuel rail off and they're cheap.
    For thine is the Cam, The Piston, and The Rod, Forever and ever (or until they break). Amen.
  5. #5 Re: Coolant Leak - LIM? :(
    Ontario, Canada
    brake cleaner fine to degrease everything?
  6. #6 Re: Coolant Leak - LIM? :(
    Ontario, Canada
    and green universal or back to dexcool?
  7. #7 Re: Coolant Leak - LIM? :(
    SWPA
    Get rid of Dex, flush the system fully and go with green.
  8. #8 Re: Coolant Leak - LIM? :(
    Ontario, Canada
    MS98014T - Lower Intake
    MS96789 - PLenum Upper
    VS50465R - Valvue Cover
    Looks like the intake kit has the o rings
  1. Coolant Leak
    By blackthunder in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-31-2013, 09:56 PM
  2. Oil Leak After *Attempting* to Replace Coolant Leak
    By CDAllenInc in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-10-2013, 12:54 AM
  3. Intake Leak & Coolant Leak
    By BlackGT1 in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-15-2012, 08:41 PM
  4. Coolant leak?
    By LuckyBambu in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-05-2010, 01:59 PM
  5. Coolant Leak
    By seeth001 in forum 3.1L V6 (LHO/LG8)
    Last Post: 12-28-2009, 01:16 AM
