Thread: leaky cylinder valves
Results 1 to 13 of 13
  1. #1 leaky cylinder valves
    Jul 2014
    New Jersey
    So i'm doing a top swap and before installing everything i like to test it. While testing i found that some of the cylinder valves leak, what should i do?
  2. #2 Re: leaky cylinder valves
    Install them and let all your cares go away.
    Or get them re-worked, but that in itself could be another downer as likely the heads are cracked between the valves on some cylinders like half of the used heads are. You can run them as is though and nothing happens, most of us have cracked heads without even knowing.
  3. #3 Re: leaky cylinder valves
    Jul 2014
    New Jersey
    Well praying its not cracked could i try lapping the valves
  4. #4 Re: leaky cylinder valves
    Nov 2011
    NY
    Yes... But have you determined what's leaking? Seals or valves not seating? That'll let ya know what to do... Also what are your plans for build? That'll guide you on how far you might want to go with those particular heads.
  5. #5 Re: leaky cylinder valves
    HUDSON
    In a dark room, take a flashlight and shine it at the valve seats and then look in the port and see if you can see light between the valve and the seats, if you do, than a valve job is in order.
  6. #6 Re: leaky cylinder valves
    Feb 2009
    flintnasty MI
    98% chance your heads are cracked.
    The heads are cracked in every 3800 ive ever delt with. I've never cared.
  7. #7 Re: leaky cylinder valves
    Nov 2011
    NY
    ^^^this^^^
    really doesn't matter unless ridiculously cracked! It's a hairline between the thin bridge of material separating the valves... No worries!
  8. #8 Re: leaky cylinder valves
    SE Level Member jimzssei's Avatar
    Sep 2014
    That says something for these 3800 motors, that they'll still run with cracks in them!
  9. #9 Re: leaky cylinder valves
    Jul 2014
    New Jersey
    Okay thanks, ill try lapping them and see what light goes through then probably just get frustrated and put on the likely cracked heads lol
  10. #10 Re: leaky cylinder valves
    Jul 2014
    New Jersey
    And yeah 3800 engines are awesome
  11. #11 Re: leaky cylinder valves
    Nearly everytime I install springs, I find there is leaking. If you tap the valves with a rubber mallet.. it'll usually seal them up.
  12. #12 Re: leaky cylinder valves
    Sep 2014
    Bill, do you mean up top, valve stem/retainer? That must snap the valve, almost shocking it?
  13. #13 Re: leaky cylinder valves
    GT Level Member Seachicken's Avatar
    Jan 2013
    Edmonton, Alberta
    Do like bill said, A lot of times the valves are being held open by carbon/deposits. If you have a friend handy take the head to the car wash. Stick the wash wand in the port and pull the trigger while the other guy bangs on the valve tip. If that doesn't fix your sealing, you would probly need a valve job. Lapping will rarely fix any sealing issues, and just put a lot of wear on the seat and valve. (Access to a valve refacer would be handy after you lapp)
    The only way to get around the cracks is to find a good pair and put some seat inserts in. Induction hardened cast iron does not make a good ex seat. Gm knows this. Planned obsolescence.
    06 Gxp, Bermuda Blue
    82 K5, Black on 35's
  1. Leaky Leaky Oil Leak - Update.. Its the pan HELP
    By Yarbeau in forum General Tech Discussion
    Last Post: 09-17-2014, 11:27 AM
  2. From misfire at cylinder 3 to a open circuit on the fuel injecter at cylinder 5
    By bbfanatic23 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-01-2010, 07:49 PM
  3. Coding cylinder 3 missfire and cylinder 3 injector port open
    By MATHEWSMAN1969 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 04-20-2010, 04:27 PM
  4. Leaky LIM
    By gtpinsc in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-11-2009, 02:23 PM
  5. Cleaning valves?Install new valves?
    By PWNED in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-12-2008, 10:06 AM
