Car is a 2000 Daytona GTP picked it up about a month ago. Never had a leak it sat and id drive it leak free.
Couple weekends ago I pulled it apart to do the LIM and install my TOG headers.
Everything went well got her all buttoned up after replacing the LIM, injector O-rings, thermostat, plugs, valve cover gaskets & grommets etc. The preventative maintenance stuff.
Now there is a pretty decent pool over oil under the car every morning. Seems to be coming from the pan. Its leaking onto the transmission pan as well but I cant pin point the location.
It isn't the valve covers as they are still bone dry.
Any thought on what it could be? Going to pull the passenger wheel and the plastic shield next to the filter and investigate deeper tonight. I tried searching but came up dry kinda like I wish the oil pan was.
