Thread: Cleaning valves?Install new valves?
Results 1 to 4 of 4
  1. #1 Cleaning valves?Install new valves?
    GT Level Member PWNED's Avatar
    Jul 2008
    Hooksett,NH
    Is it ok to say clean the valves them self with a "green type cookie" on an angle grinder? To remove all the deposits. I had the valves them self in the cuda machine and they still have depostis on them.
    The exhaust valves them self look pitted where it seals to the head it self. If i purchased new valves is it acceptable to just put them in or is a valve job necessary.(Not too sure what it all means)3 angle valve job with the heads and the valve it self.
    02 Regal GS
    ZZP Headers/ 42#/ Intake/ S4 zzp sc/ Ported Lim/ LQ4/ HPT/ 3" to SuperTurbo/ Phenolic IC with 2.8 pulley/ XP/ Ported Heads
    PB-------12.3 @ 110.......312hp/350tq
  2. #2 Re: Cleaning valves?Install new valves?
    Charles City, IA
    You will want to have the valves seated for your head (valve job). The old ones will have worn in the seats and the new ones might not seal correctly if you don't.
    SMGPFC Two Nipple General
  3. #3 Re: Cleaning valves?Install new valves?
    Aug 2008
    Flushing/Flint, MI
    you will need to lap the valves a valve job would be good but you can get by with just hand laping the valves.
  4. #4 Re: Cleaning valves?Install new valves?
    Jul 2008
    Hooksett,NH
    Ok thanks for the info. Will probobly just lap them.
    02 Regal GS
  1. cleaning up the outside
    By crshoveride in forum General Tech Discussion
    Last Post: 06-03-2011, 09:09 AM
  2. Cleaning Engine Bay
    By stlmo_gtp in forum Visual/Body Modifications
    Last Post: 08-19-2008, 01:42 AM
  3. I wanna talk heads and valves.
    By Reptile in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-10-2008, 11:07 PM
  4. cleaning a sub
    By MTXGTP in forum Audio, Security & Visual Electronics
    Last Post: 07-11-2008, 01:53 PM
  5. Valves rattle
    By johndaysGT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-12-2008, 05:46 PM
