Thread: boost question
Results 1 to 20 of 29
  1. #1 boost question
    Nov 2014
    Iowa
    I have a 3.5 pulley on my ported and polished charger. Have aftermarket intake and full exhaust minus headers. 1998 gtp
    My boost gauge only reads 5 pounds maximum. My question is if that is a normal number for a pulley of that size and charger set up. Thanks
  2. #2 Re: boost question
    Unplug the BBV solenoid and see what it reads on a WOT run, it will likely spike up much higher.
    Stock psi is 6-7 if thats saying anything.
    I'd worry about ping/knock without atleast a 3in downpipe on there.
  3. #3 Re: boost question
    Jul 2012
    Chicago
    Pulley size is a little small with no exhaust mods. Got an Aeroforce or something similar?
    -Carl
  4. #4 Re: boost question
    Nov 2014
    Iowa
    Don't see any excessive knock with the tech 2. My gauge is a glowshift if that's what your asking
  5. #5 Re: boost question
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    Quote Originally Posted by SLICK4TIME View Post
    So you see some knock? How much? I'm just curious.
    2012 F150 STX
    - Gonna be a race truck
  6. #6 Re: boost question
    Mercer, Pa
    Ported and polished blower? Is there coating still on the rotors? Who ported it and what it look like? Any pictures?
  7. #7 Re: boost question
    Nov 2014
    Iowa
    Yes coating is fine. The blower is off of my buddies 02 gtp. I ported it myself. I had the same readings before the new blower
  8. #8 Re: boost question
    maybe the bbv solenoid is bad? that lever move on it when you rev the engine in park?
  9. #9 Re: boost question
    Nov 2014
    Iowa
    When i rev it in park i never reach boost. Only stay in vacuum. Which i figured was normal thinking load is needed
  10. #10 Re: boost question
    Mercer, Pa
    No boost in park or neutral, computer prevents boost.
  11. #11 Re: boost question
    Nov 2014
    Iowa
    Thats what i figured. Ill have to check the bbv lever when i rev it after work.
  12. #12 Re: boost question
    it should move.
  13. #13 Re: boost question
    Nov 2014
    Iowa
    Little to no knock. The bbv works and i tried running it with the bbs unhooked electrically and unhooked and plugged vacuum line. Did not see any difference
  14. #14 Re: boost question
    what do you consider little to no knock? actual numbers are nice.
    any pics of this port job? maybe you over did it.
  15. #15 Re: boost question
    Nov 2014
    Iowa
    A degree or 2 if i remember correctly. Here is a picture of my old housing and the ported one before final finishing. Like i said the numbers are the same as they were before the new charger
  16. #16 Re: boost question
    Mercer, Pa
    A degree or 2 if i remember correctly. Here is a picture of my old housing and the ported one before final finishing. Like i said the numbers are the same as they were before the new charger.
    Looks like you removed to much material.
  17. #17 Re: boost question
    i think you took to much off. but im no pro at porting.
    you had the same boost with the 3.5, or did you have the 3.8 before the port job?
  18. #18 Re: boost question
    Nov 2014
    Iowa
    I had the 3.5 pulley on the old charger yes
  19. #19 Re: boost question
    have you sprayed carb cleaner at all the vac lines, the bbv the TB gasket, blower to lim, evap solenoid, map sensor? the t under the blower snout.
    spray while the car is idling, if the idle jumps up when sprayed you found a leak area.
  20. #20 Re: boost question
    Nov 2014
    Iowa
    I recently did all the gaskets on the top of the engine and dont believe to have any vac leaks there. I will double check all my fittings and lines when i can.
  1. Low boost, block off boost bypass solenoid. Full boost returns..
    By TexasTanker19kilo20 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-23-2016, 11:14 AM
  2. boost question
    By JPGgtp in forum General Tech Discussion
    Last Post: 06-11-2013, 11:00 PM
  3. boost question
    By james gilbert in forum General Grand Prix Discussion
    Last Post: 03-18-2013, 05:16 PM
  4. boost question
    By str3etgl0w in forum General Tech Discussion
    Last Post: 07-20-2012, 11:14 PM
  5. boost gauge question
    By gtpeddie in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-25-2012, 07:16 PM
