Thread: boost gauge question
Results 1 to 14 of 14
  1. #1 boost gauge question
    Jan 2012
    Philadelphia
    first off i searched on here for a little bit for information but looking to hear more. i installed my boost gauge today and hooking it up is not the problem. i ran it to the vac line on the top of the blower where the vac tree is. i ran it there because i herd of someone else on here doing that and i want to keep the line away from heat. it work but i dont think the reading is that accurate on it. when at idle it reads 20 for the vac side and when i hit WOT it shows 0 PSI. so i think i have it hooked up to the wrong line. what lines did you guys who have one run yours to? and where should i run mine to if its not in the right spot. i can get pics tomorrow any help is appreciated
  2. #2 Re: boost gauge question
    line needs to see booost.
    So run it to the line Under the blowers snout.
  3. #3 Re: boost gauge question
    Jan 2012
    Philadelphia
    that's where i had it at first but it gets real hot in that area, do you think it will mess up the line? ill look tomorrow for a place around that's not too hot if there is one
    GTP Level Member dazedandconfused's Avatar
    Sep 2011
    bedford, Pa
    I randomly started tapping vacuum lines until I found one that read boost lol. I'd like to see which one is the "correct" one myself
    97 gtp, cone filter mod, downpipe and glasspack to stock muffler mod, 180* t-stat mod, bad driver mod
  5. #5 Re: boost gauge question
    The stock lines are plastic?
    And are in the heat 100% of the time?
    Heat is going to be an issue?
  6. #6 Re: boost gauge question
    Jan 2012
    Philadelphia
    what line are you running it on now?
  7. #7 Re: boost gauge question
    Jan 2012
    Philadelphia
    yea never thought about it like that
    its just the boost vac line seems a lil more thinner and more delicate
    and also i got rid of alot of my original plastic lines because they broke when i took the blower off
    so i replaced them with regular vacuum line not the plastic line
  8. #8 Re: boost gauge question
    97 GTP blowers have a line for the LIM to MAP.
    98-03 blower run a line from the boost control solenoid to the FPR to the LIM to MAP. Its one huge line.
    This is a 97 style blower.
    Boost Gauge Install
  9. #9 Re: boost gauge question
    Jan 2012
    Philadelphia
    thanks for the help man
  10. #10 Re: boost gauge question
    SE Level Member DanielGTP's Avatar
    May 2012
    United States
    I had the same problem with my boost gauge when i 1st hooked it up. FFDP is right there is a factory boost line that runs under the snout. Once i T'd into that it worked fine. Good luck!
  11. #11 Re: boost gauge question
    Jan 2012
    Philadelphia
    that's where ill probably tap into then thanks for the help guys!
  12. #12 Re: boost gauge question
    GTX Level Member asite57's Avatar
    Oct 2011
    Michigan
    Boost Gauge Install
    i have a 99 gtp and theres a t fitting type thing under there as well isnt that where id tap into?
  13. #13 Re: boost gauge question
    Jan 2012
    Philadelphia
    i tried another spot, tapped into mine right under the snout but still have to try another spot its now reading PSI but only like 3-4
  14. #14 Re: boost gauge question
    Texas
    Quote Originally Posted by gtpeddie View Post
    Is it the stock S/C pulley? It will read like 5-6 at least mine did.
    When I was S/C I t'd mine right below the snout and never had an issue. The vac side at idle should be reading -18 to -20
    85 Corvette
    01 TA
    03 Z06
  1. Quick boost gauge question
    By Bluemagic in forum General Tech Discussion
    Last Post: 04-24-2011, 09:30 PM
  2. hey guys, question about boost gauge
    Last Post: 12-13-2010, 10:55 PM
  3. boost gauge question
    By GMPUNK in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-26-2010, 12:32 PM
  4. Factory boost gauge question (98GTP)
    By JoelW98GTP in forum General Tech Discussion
    Last Post: 11-08-2009, 08:06 PM
  5. question about boost gauge on a 98 gtp
    By millfire517 in forum General Tech Discussion
    Last Post: 02-09-2009, 08:31 PM
