Thread: steering/traction control problem
Results 1 to 7 of 7
  1. #1 steering/traction control problem
    May 2012
    Thunder Bay, Ontario, Canada
    Hello
    When i cold start the car and warm it up for a bit, i then go to back out of the drive way and turn the steering wheel i get a grinding and or vibration for a moment then the traction control light pops up. when i accelerate straightforward it stops. I know my steering shaft is ****ed but as far as i knew this wouldnt cause that. What could it be or am i wrong?
    Thanks
    2007 Grand Prix GT SE 3.8 S/C "The Black Beauty"
    1994 Chevy C1500 4.3L "One wheeler Peeler"
    love/hate relationship.
  2. #2 Re: steering/traction control problem
    abs self test, they all do it, its normal.
    it makes no difference what direction you move the car, or turn the wheels, it does it every time the car is started up and driven off.
  3. #3 Re: steering/traction control problem
    May 2012
    The car has only just started doing this though.
  4. #4 Re: steering/traction control problem
    May 2012
    Its also more of a notification then a light.
  5. #5 Re: steering/traction control problem
    its always done it. you never heard it before. some times its silent, others it makes that rake being drug on pavement sound.
  6. #6 Re: steering/traction control problem
    Scotty you didnt read this fully.
    He gets a noise and his traction control light comes on. Though the ABS noise is normal, the T/C light is not a normal thing to have happen when turning in reverse.
    If it was my car, I would remove and clean all connectors from the ABS hubs, check wires at the ABS module and see if anything else looks odd. Or if you had a scan tool you could watch all the ABS sensors at once and see if one drops out and thats why the light trips.
  7. #7 Re: steering/traction control problem
    May 2012
    I have access to a scan tool ill try it out
  1. ABS, Traction Control and Variable Effort Steering disabled.
    By cameron92 in forum Brakes/Suspension/Chassis
    Last Post: 08-15-2014, 07:14 PM
  2. traction control problem
    By Martin 04 in forum General Tech Discussion
    Last Post: 07-02-2014, 11:12 AM
  3. Problem with ABS and Traction Control
    By Widetrackjohnny in forum Brakes/Suspension/Chassis
    Last Post: 12-24-2012, 11:31 AM
  4. ABS / Traction Control / Vairable Effort Steering lights all on
    By anarchy in forum Brakes/Suspension/Chassis
    Last Post: 06-27-2012, 08:40 AM
  5. Service ABS, traction control, variable steering
    By Lionel in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-31-2011, 08:09 PM
