Thread: ABS, Traction Control and Variable Effort Steering disabled.
Results 1 to 12 of 12
  1. #1 ABS, Traction Control and Variable Effort Steering disabled.
    Grand Pricks cameron92's Avatar
    May 2011
    Orangeville, Ontario, Canada
    My car has been making a howling noise from the rear tire for a while now. I'm pretty sure its a wheel bearing but it the sound doesn't get louder when turning. Today I was driving it and my ABS, Traction Control and Variable Effort steering lights all came on saying disabled. Could this be a wheel bearing issue?
    Edit: Car is an 06 Grand Prix GT
  2. #2 Re: ABS, Traction Control and Variable Effort Steering disabled.
    The Boss Iceman6669's Avatar
    Jun 2011
    More then likely yes. Bad hubs cause all those issues.
    2011 F-150 Yote powered
  3. #3 Re: ABS, Traction Control and Variable Effort Steering disabled.
    May 2011
    How would I go about checking the wheel hub. Pulling the wheel at 9 and 3? Checking for frayed wires?
  4. #4 Re: ABS, Traction Control and Variable Effort Steering disabled.
    jack the wheel up, lugs still tight, then grab the top of the wheel with both hands, push and pull slowly, and firmly, if the hub is loose you'll feel it.
    you can also watch the rotor if it moves inside the pads the hub is also bad. rotor is bolted to the hub between the wheel. caliper wont move as its bolted to the knuckle.
  5. #5 Re: ABS, Traction Control and Variable Effort Steering disabled.
    May 2011
    Would that be safe to do with a scissor jack? I don't own a regular jack or stands.
  6. #6 Re: ABS, Traction Control and Variable Effort Steering disabled.
    Moderator Russosaur's Avatar
    Apr 2012
    Dayton, OH
    Isnt that the stock jack? I dont like them, especially because they use the pinch welds. You can pickup a jack and stands from HF for not that much and I'm sure it will gets its moneys worth of uses. If your rockers are soild you could use it I guess just don't get under the car where you can get smushed.
    Edit: just saw you have an 06 so pinch welds shouldnt be rusted or missing.
    Sent from the Milky Way
    2012 F150 STX
    - Gonna be a race truck
  7. #7 Re: ABS, Traction Control and Variable Effort Steering disabled.
    if your rockers are still solid you can use it, its there to take a tire off, to get it off it needs to get the tire off the ground, so it will work to test a bad hub.
    you can get a cheap 2 ton little floor jack style jack for like 20 us most of the time. id get one, makes life easy.
  8. #8 Re: ABS, Traction Control and Variable Effort Steering disabled.
    Jul 2010
    Coquitlam,BC,Canada
    I'd be leary of doing this with the scissor jack. Mine pretzeled on me when I was doing my motor mounts; raised the car to remove the stands, started lowering the car then rapid lower occured. Had to use my hi-lift jack to raise the car to get the blocks of wood out. Not a cool experience.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  9. #9 Re: ABS, Traction Control and Variable Effort Steering disabled.
    May 2011
    Well I did it with the scissor jack. No play in the hub. But still howls like crazy.
  10. #10 Re: ABS, Traction Control and Variable Effort Steering disabled.
    Apr 2012
    Dayton, OH
    Probably still the bearing if its howling, and if your ABS is random2 kicking in you might have broken wires or almost broken wires. Mine did that, ABS would randomly come on (I assume from the chnage in resistance or whatever from the broke wires enough to triggee the ABS) then the ABS light came on full time.
    2012 F150 STX
  11. #11 Re: ABS, Traction Control and Variable Effort Steering disabled.
    Jun 2011
    I had no play in either of mine but both made noise.
  12. #12 Re: ABS, Traction Control and Variable Effort Steering disabled.
    Jul 2010
    Coquitlam,BC,Canada
    Quote Originally Posted by cameron92 View Post
    Bad bearing or you changed the wrong side.
    Chris B
    2009 CX-9
    ** SOLD ** 2002 GT
  1. ABS Service, Traction Control Service & variable effort steering.
    By CyxRyan in forum General Grand Prix Discussion
    Last Post: 06-10-2017, 08:43 PM
  2. Variable effort steering
    By SCGT06 in forum General Tech Discussion
    Last Post: 06-16-2014, 02:13 PM
  3. ABS / Traction Control / Vairable Effort Steering lights all on
    By anarchy in forum Brakes/Suspension/Chassis
    Last Post: 06-27-2012, 08:40 AM
  4. Service ABS, traction control, variable steering
    By Lionel in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-31-2011, 08:09 PM
