Thread: traction control problem
Results 1 to 14 of 14
  1. #1 traction control problem
    SE Level Member Martin 04's Avatar
    Oct 2008
    queens
    i have an 04 gt, i bought the car about 2 months ago and the traction control button doesnt work, it wont shut off the traction, i know the trac light works because when i start the car it turns on for a second with all the other lights any help ? also could this be affecting my braking because when ever it rains and i get on the brakes hard i start sliding like nothing i tried changing the front rotors and pads
  2. #2 Re: traction control problem
    Oklahoma
    Well I would first suspect a wheel bearing, since the ABS sensor is built into the bearing, but that normally causes the traction control light to come on if they fail, indication that the TCS system is off.
    But since your's is not that would lead me to think something along the lines of a blown ABS fuse or something along those lines.
  3. #3 Re: traction control problem
    GTX Level Member Toofastgs's Avatar
    Tulsa, Ok
    a low tire can affect traction light too
    00' GTP 350/420 - Retired
    98' GS - Sold
    Current - Lexus ES300
  4. #4 Re: traction control problem
    Oklahoma
    Quote Originally Posted by Toofastgs View Post
    Good point!
  5. #5 Re: traction control problem
    GT Level Member pski920's Avatar
    Oct 2008
    Endicott NY
    in my 99 gt i have the light "on" and i figured it was a sensor, but is there any trick on how to figure out which one it is without replacing them one by one?
  6. #6 Re: traction control problem
    Oklahoma
    Not really, you have to have a scan tool capable of reading ABS codes and that usually means taking it to a dealer to be read with a Tech II.
  7. #7 Re: traction control problem
    Oct 2008
    Endicott NY
    ahh, ok. the scan tool i have (MAC cheapie) must not have the capabilities. thanks, and i like your avatar pic! i'm tall so i'd go first on a golf course i guess! haha....
  8. #8 Re: traction control problem
    Jul 2008
    Poteau Oklahoma
    if your really lucky like me, you need a EBCM.
    98 chevy truck
    83 Olds cutlass
    86 Olds cutlass
    06 se gold
  9. #9 Re: traction control problem
    wisconsin
    I bought an 05 GTP used and I had the same issue and when I replaced the rotors and brakes on the front I found the wire going to the anti lock brake was cut. I repaired the wire and everything went back to normal. hope this helps
  10. #10 Re: traction control problem
    Oct 2008
    queens
    i kno this is from a long time ago but u were right it was a wheel bearing
  11. #11 Re: traction control problem
    Jul 2013
    Capron, IL
    And nobody touched the second question of the original post....
    The TCS has nothing to do with braking. That's where your ABS comes in...or doesn't.
  12. #12 Re: traction control problem
    you dont say, but is the abs light on? and svs light? if your brakes are locking up you should have a dummy light or two or 3 lit up.
    locking brakes means the abs and t/c are disabled.
  13. #13 Re: traction control problem
    Aug 2011
    'Merica
    only a 4 year old thread.........
  14. #14 Re: traction control problem
    smash me in the face please, damn it!!!
  1. ABS & Traction Control Lights
    By 98GP*GT in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 11-08-2009, 06:40 PM
  2. Traction Control Issues
    By ssm90GT in forum General Tech Discussion
    Last Post: 09-02-2009, 11:31 PM
  3. 2004 GTP traction control issue
    By bentendo92 in forum General Tech Discussion
    Last Post: 02-24-2009, 08:57 PM
  4. ABS / Traction Light
    By bcrosby51 in forum General Tech Discussion
    Last Post: 12-20-2008, 06:10 PM
  5. !!?best Way To Launch?!! (traction Control)
    By BLACKEDOUTGTP in forum Track Sessions and Kills
    Last Post: 07-29-2008, 12:20 AM
