Thread: rough idle, possible misfire?
Results 1 to 16 of 16
  1. #1 rough idle, possible misfire?
    GTP Level Member 04lss's Avatar
    Sep 2014
    Richmond Virginia
    I have been driving the GTP this week and finding out the issues it has (new tie rod, new radiator so far)
    It seems like it has a misfire at idle, it runs rough and the idle moves around. I remember the l67 in my monte was rough at idle but this seems worse. the car also seems to have a slight surging feeling when lightly accelerating.
    if i put my foot on the brake and give it gas in gear it doesnt seem to stumble, but its not completely smooth either.
    its not affecting driving, but its bucking the F out of me.
    anythoughts on what this could be?
    FYI I put in new plugs last weekend.
    I have also been ruing injector cleaner.
  2. #2 Re: rough idle, possible misfire?
    Year?
    Clean the TB as a starting point.
  3. #3 Re: rough idle, possible misfire?
    Sep 2014
    Richmond Virginia
    its a 97 205k, whats the best way to clean? pull it off and spray with parts cleaner?
  4. #4 Re: rough idle, possible misfire?
    yup, remove the maf before cleaning it.
    clean the maf with maf cleaner only.
  5. #5 Re: rough idle, possible misfire?
    Sep 2014
    Richmond Virginia
    Thanks!
  6. #6 Re: rough idle, possible misfire?
    GT Level Member Flip97GTP's Avatar
    May 2013
    Ft. Lauderdale, Florida
    Check your fuel regulater vacuum hoses for cracks or breaks.
    My 1997 Grand Prix GTP progress build thread!
    Mods At The Moment: 160+ Amps Alternator.
    Mods I Will Be Doing In 2015: Speed Daddy Headers, 3.4" Modular Pulley System, Open Air Intake, BillBoost Tune, TransGo SK® 4T65E Transmission Shift Kit, 180* Thermostat
  7. #7 Re: rough idle, possible misfire?
    GT Level Member Trett93's Avatar
    Jun 2014
    Ontario Canada
    any check engine lights? mine bucks the **** outta me through town, but my afr drops to like 10 and the car goes stupid.
    3800 series 2 SC swap, 180 tstat, 5 speed swap, stage 3 clutch, machined camaro flywheel,
    s1x cam, rollmaster double roller, crow cams 105# springs, TR6's, overkill tune, ssbc big brake kit..more soon.
  8. #8 Re: rough idle, possible misfire?
    GT Level Member lewis1952's Avatar
    Sep 2013
    tulsa okla
    when cleaning the MAF you will see fine hair like wires clean gently with cotton swab do not break them.
  9. #9 Re: rough idle, possible misfire?
    Quote Originally Posted by lewis1952 View Post
    are you high?^^^^^ DO NOT TOUCH THEM LITTLE WIRES WITH JACK SH IT. SPRAY THEM WITH MAF CLEANER, LET IT DRY, RE INSTALL.
  10. #10 Re: rough idle, possible misfire?
    Nah scotty, cleaning with a cotton swab or ear cleaner is okay sometimes.
    Have to do it on some vehicle at work, you'd be suprised how much more stuff comes off even after you spray it down.
  11. #11 Re: rough idle, possible misfire?
    well lets say this, if its not shining after spraying, then use a swab lightly. its best not to play with them. i could see them getting gummed up good and thick in some cars.
  12. #12 Re: rough idle, possible misfire?
    Sep 2014
    Richmond Virginia
    Ill go ahead and mess with it on saturday, while im doing the Rad, and the coupler.
    off topic, but whats the best way to launch one of these for the best 0-60.
    im trying to check and see how much power its lost from wear and tear.
  13. #13 Re: rough idle, possible misfire?
    Quote Originally Posted by Trett93 View Post
    And you've been told to get your codes for misfires tuned out. Your pcm is pissed off with you.
  14. #14 Re: rough idle, possible misfire?
    Jun 2014
    Ontario Canada
    I know it is bill, but it could possibly be an o2, I had 2 reasons why my pcm was pissed at me, one of which still needs to be dealt with, the misfire code,
  15. #15 Re: rough idle, possible misfire?
    GT Level Member JamesIvey24's Avatar
    May 2011
    Illinois
    If your MAF is indeed bad, then cleaning it with that $8 snake oil in a spray can won't help. Feel free to try it. But also, unplugging it will give you some real results.
  16. #16 Re: rough idle, possible misfire?
    Sep 2014
    Richmond Virginia
    Quote Originally Posted by jamesivey24 View Post
    I cleaned the maf, didnt really help, i did find the honeycomb cloged with a bunch of stuff. I unplugged it, still idled ruough, so im going to check the hoses when im doing the snout.,
    On another note I did a 0-60 run with a 3mph rolling start, and got a time of 6.5 seconds. I am very pleased for a car with 206k miles, Looks like i dont have any catching up to do.
  1. Rough idle
    By Jonarin in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 10-22-2014, 04:16 PM
  2. 99 GTP Troubleshooting- rough idle, misfire? No codes (warning very NOOB)
    By Juxtaghost in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-17-2012, 02:29 PM
  3. Rough Idle with intermittent idle miss
    By 99GTPMLA in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-09-2012, 12:12 PM
  4. Odd rough sound at idle...possible misfire?
    By Spartanzz in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-09-2011, 01:06 AM
  5. rough idle
    By 02gtpalder in forum General Tech Discussion
    Last Post: 03-07-2010, 12:02 AM
