Thread: Help please!
Results 1 to 20 of 32
  1. #1 Help please!
    SE Level Member krysp432's Avatar
    Sep 2012
    Andrews Tx
    I replace the LIM gaskets on my L67. For some dumb reason, I dont know why, I took off the belt tensioner that is attached to the distributor. Now for the life of me i cannot put back on right. What am I missing? There are two bolt, one for the actual pulley, and another for holding in place that you have to use a 1/4" socket to take off. It has a male STAR connection. Thanks in advance for any help. I have searched and the "how to section" does not exist. It just shows a blank page.
  2. #2 Re: Help please!
    Which one??
    A
  3. #3 Re: Help please!
    Sep 2012
    Andrews Tx
    On the diagram #3. On your pic its the black and silver. Thanks
  4. #4 Re: Help please!
    Sep 2012
    Andrews Tx
    Every time I tighten it up, where the Star Male thread is no longer reachable it still feels very loose. Not like the tensioner is giving out, but like its not tightly connected to the engine. Thanks
  5. #5 Re: Help please!
    your using a deep socket right?
  6. #6 Re: Help please!
    Sep 2012
    Andrews Tx
    None of the 15mm sockets fit. The opening is too tight for any 15 mm or 5/8 socket.
  7. #7 Re: Help please!
    how did you get it off then?
    i use a 12 point socket, kobalt. fits perfectly inside the tensioner. pretty sure its a 13 mm nut too aint it?
  8. #8 Re: Help please!
    Sep 2012
    Andrews Tx
    You can unscrew it all the way out using the male star connection. And I wish it was a 13mm .
  9. #9 Re: Help please!
    but you cant make it tight the same way now?
    find a 12 point socket you may have better luck.
  10. #10 Re: Help please!
    Sep 2012
    Andrews Tx
    Thanks for yalls help I got it. I had to do a little improvising. I grinded down a 15mm socket. Thanks @Scottydoggs and @fiverfingerdeathpunch I really do appreciate the pics. I couldnt find a picture of the pulley set ups without the belts on and an actual "real picture". Thanks again for yalls help about to go crazy! Been inside my girl for the past 6 hours! I dont know how she does it but she can keep me going all night! LOL
  11. #11 Re: Help please!
    The reason why your 15mm sockent didn't fit is because you put the wrong nut in there. It is a 13mm head nut with a small shoulder and made to fit a 10 x 1.5 thread.
  12. #12 Re: Help please!
    Sep 2012
    Andrews Tx
    Alrighty then. Had problems with the starter, I believe had the wires touching and connected wrongly...So trying to start her up and she is not giving in. Shell try but no start. The fuel pump is going crazy, making noises. I believe there is air in the lines, but i bled the fuel rail many times but no luck. I am going to try to replace the fuel pump, but if im getting fuel to the rails, then there shouldnt be anything wrong with the pump...right? Will double check the fuses and what not. Thanks
  13. #13 Re: Help please!
    STOP....
    check your battery connections. Sounds like you aren't getting enough power
  14. #14 Re: Help please!
    Fuel lines will bleed on their own in a millisecond.
    Starter...would you like a picture of how the wires go?
  15. #15 Re: Help please!
    Sep 2012
    Andrews Tx
    Yes please on the starter pic. At first hook up she sparked really bad at battery and the starter was going nuts. After I thought I re wired correctly, I hooked up the battery and she didnt spark any, everything was fine. Thanks
  16. #16 Re: Help please!
    Sep 2012
    Andrews Tx
    Going to go buy a New battery and see if thats the case. The battery on her now is old and been sitting for about 6 months rolling around in the back of my truck. Thanks
  17. #17 Re: Help please!
    Here's a link to a lot of different helpful type pictures. Password is "Boosted"
    http://s20.photobucket.com/user/bill...ful%20Pictures
    Starter pics
    and ground
  18. #18 Re: Help please!
    Sep 2012
    Andrews Tx
    Awesome! thanks will try the new battery. I had her on jumper cables with my truck and she sounded better trying to start. The fuel pump didn't "cough" when she had good power, so Im hoping it needs a new battery. Thanks again
  19. #19 Re: Help please!
    GTP Level Member tomtom123's Avatar
    Aug 2011
    Michigan
    If not the battery, I bet ground! Since thats kinda what I was dealing with not too terribly long ago and had issues of the car not starting
  20. #20 Re: Help please!
    BTW..did you spot the correct nut for the tensioner yet?
