Thread: P0300 help - engine misfiring and stalling upon startup
Results 1 to 11 of 11
  1. #1 P0300 help - engine misfiring and stalling upon startup
    Jun 2014
    Chicago
    I've got an '02 GTP with just over 120k miles. I had 2 codes, P0300 and P0130. P0130 was for the upstream oxygen sensor, I just replaced that yesterday so that should be good. Second is for the engine misfiring. I know there are some other threads on this but I wanted to see if anyone had some ideas with my specific symptoms. The car starts up no problem, but a few seconds later it dies. It eventually stays running, seeming like once it gets warmed up it performs better. Still, it isn't running smoothly and rpms fluctuate when idling.
    Going in order of obd-codes.com, here's what some potential problems are:
    Spark plugs: I haven't actually tested the spark plugs but they were just replaced at 100k miles so that wasn't too long ago.
    Spark plug wires: I didn't replace the wires when changing the spark plugs as the looked to be in good shape then but I tested the wires with an HEI tester today and they performed just fine.
    Coil pack: I got a coil pack, tried swapping in the new one in each of the three positions with no luck.
    Oxygen sensor: Just replaced the upstream one since that is what the code was pointing towards.
    Faulty fuel injector: have not tested
    Burned exhaust valve: have not tested
    Faulty catalytic converter: have not tested
    Stuck/blocked/leaking EGR valve/passages: have not tested
    Faulty camshaft position sensors: have not tested
    Defective computer: have not tested
    Do any of these have a higher chance of causing the engine to stall immediately after startup? Or does anyone have some direction on what to test next?
  2. #2 Re: P0300 help - engine misfiring and stalling upon startup
    What brand plugs?
    If you have the ablilty to do so, swap ICM's with another 3800 car and see if it runs better.
  3. #3 Re: P0300 help - engine misfiring and stalling upon startup
    Jun 2014
    Chicago
    What brand plugs?
    The plugs are ACDelco 41-101. I don't know of any 3800 I could swap with to test..
  4. #4 Re: P0300 help - engine misfiring and stalling upon startup
    SE Level Member jimzssei's Avatar
    Sep 2014
    Idle air control ... Mass air ... closed loop issues are tough to trouble shoot sometimes.
    Sent from Ohio
  5. #5 Re: P0300 help - engine misfiring and stalling upon startup
    Jun 2014
    Chicago
    Quote Originally Posted by jimzssei View Post
    Sent from Ohio
    Ok, so I've got some new information that might direct this better. I picked up some mass air flow cleaner. Took out the sensor, sprayed it, let it dry, put it back in. Started up the car and it sounded pretty good actually and stayed running, the rpms were not fluctuating. So I let it go a few minutes and it sounded fine. Turned it off, let it sit a few minutes and tried again. Same thing. Stepped away for 20 min, came back and tried to start it, it would turn on then stall again just like before. Hmm. So I took off the MAF sensor, cleaned it again and put it back it. The car ran. So then I wanted to drive it around the block and see how it did. I made it about 100 feet and the engine stalled. It gave no indication it was struggling, just died. So I got it going again and now it is back in the garage. So close to having it fixed.
    Could this mean I just need to replace the MAF sensor with a new one?
  6. #6 Re: P0300 help - engine misfiring and stalling upon startup
    What year is the car.
  7. #7 Re: P0300 help - engine misfiring and stalling upon startup
    Read the post bill, it's in there.
  8. #8 Re: P0300 help - engine misfiring and stalling upon startup
    Crap... I swear I did... Better have more caffine
  9. #9 Re: P0300 help - engine misfiring and stalling upon startup
    May 2012
    Where winter never ends
    New maf possibly. Do you have access to a data scanner? see if the maf is reporting data?Unplug the maf and drive it. see what happens. Dont romp on it just drive
    2000 Regal - Winter Beater
  10. #10 Re: P0300 help - engine misfiring and stalling upon startup
    Jun 2014
    Chicago
    Quote Originally Posted by DualDrillMe View Post
    I have an OBD2 scanner and the torque app on my phone. MAF sensor was giving a readout of 212.5 g/s sitting in the garage. Then I unplugged it and drove it. I kept low rpms and stayed under 20mph but it never stalled and seemed to run okay.
  11. #11 Re: P0300 help - engine misfiring and stalling upon startup
    Jun 2014
    Chicago
    I ordered a new MAF sensor and it should be here tomorrow. So I'll replace that and see how things go. I just started it up now with the maf sensor unplugged. The rpm's were still fluctuating but it wasn't low enough to seem like it was going to die. Is this common with having the sensor unplugged? Should it still flutter like that? Or am I looking at an additional issue?
  1. Engine stalling at Startup P0102 P0443 2005 GP
    By CDH4RC in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 09-14-2013, 10:50 PM
  2. RE: Stalling @ startup (cold only)
    By pbxcomm in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-30-2012, 07:54 PM
  3. Intermittent stalling on startup, then fires right up on second try. Ideas?
    By ChvyTrcksFrdScks in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 08-03-2010, 06:17 PM
  4. Random Misfiring P0300 Code
    By spcguy88 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 05-10-2010, 09:44 PM
  5. Help!! '01 GTP misfiring/idiling rough at startup!!
    By fatride99 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 02-06-2008, 06:20 PM
