Thread: changed thermostat and now shifting weird
Results 1 to 4 of 4
  1. #1 changed thermostat and now shifting weird
    Oct 2012
    canada
    Can an engine thermostat have anything to do with the tranny shifting? Seems to want to hold second gear a long time before shifting since I changed the thermostat. I have an engine code too but haven't had the chance to get someone to read it.
  2. #2 Re: changed thermostat and now shifting weird
    not likely, get the car scanned for that code. it will lead you to the problem.
  3. #3 Re: changed thermostat and now shifting weird
    Enfield, CT
    When you changed the stat, did you unplug the TPS, MAF, or IAC? if, so did you forget to plug them back in?
  4. #4 Re: changed thermostat and now shifting weird
    Donating Users timboku's Avatar
    Montgomery, IL
    Did you unplug or fray the coolant temp.wire that goes over one.of the thermostat housing nuts? Not sure.that would cause shifting.issues though.
    Sent from my SCH-I545 using Tapatalk
    2002 GTP..DD.. Topswapped Gen V L26, XP cam, Full Size IC, E85, 2.6 Pulley,SD Headers, K&N Intake, N*/Lq4,FP Rewire, TEP Trans, F body Fronts, GXP Rear Brakes, LE Spoiler, AGXs with vogtland springs, bonni gxp rims, Timboku Tuned
    1995 Cutlass Supreme Convertible...Soon to be L32Swapped.....2005 GXP Stock
  1. No power after shifting and weird noises
    By Monroe8822 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 11-12-2013, 10:22 PM
  2. Replies: 4
    Last Post: 09-02-2013, 10:55 PM
  3. Weird Shifting Problem
    By Btownmills in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 06-17-2012, 08:21 AM
  4. Weird Shifting Problem
    By Btownmills in forum General Tech Discussion
    Last Post: 06-14-2012, 11:41 PM
  5. Weird shifting problems
    By Sick03L in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-09-2008, 07:48 PM
