I've got an '02 GTP with just over 120k miles. I had 2 codes, P0300 and P0130. P0130 was for the upstream oxygen sensor, I just replaced that yesterday so that should be good. Second is for the engine misfiring. I know there are some other threads on this but I wanted to see if anyone had some ideas with my specific symptoms. The car starts up no problem, but a few seconds later it dies. It eventually stays running, seeming like once it gets warmed up it performs better. Still, it isn't running smoothly and rpms fluctuate when idling.
Going in order of obd-codes.com, here's what some potential problems are:
Spark plugs: I haven't actually tested the spark plugs but they were just replaced at 100k miles so that wasn't too long ago.
Spark plug wires: I didn't replace the wires when changing the spark plugs as the looked to be in good shape then but I tested the wires with an HEI tester today and they performed just fine.
Coil pack: I got a coil pack, tried swapping in the new one in each of the three positions with no luck.
Oxygen sensor: Just replaced the upstream one since that is what the code was pointing towards.
Faulty fuel injector: have not tested
Burned exhaust valve: have not tested
Faulty catalytic converter: have not tested
Stuck/blocked/leaking EGR valve/passages: have not tested
Faulty camshaft position sensors: have not tested
Defective computer: have not tested
Do any of these have a higher chance of causing the engine to stall immediately after startup? Or does anyone have some direction on what to test next?
