Thread: Evap System
Results 1 to 20 of 28
  1. #1 Re: Evap System
    GT Level Member Flip97GTP's Avatar
    May 2013
    Ft. Lauderdale, Florida
    its the check engine light on for the missing evap system? it may have been tunes out if theres no light on for it.
    if you have a code post it up. theres more then just what you see under the hood, theres a canister tank and another solenoid in the rear quarter panel under the gas filler neck. that could be missing too.
    Thanks for the diagram that's a big help.
    Yes the check engine light is on. I did a scan on her and these codes come up p0300 and p0441. I think the p0300 code is from my from my fuel pump regulator because the fitting that goes on the nipple dry rotted off.
    I have a thread on this here
    http://www.grandprixforums.net/threa...84#post1069784
    My 1997 Grand Prix GTP progress build thread!
    Mods At The Moment: 160+ Amps Alternator.
    Mods I Will Be Doing In 2015: Speed Daddy Headers, 3.4" Modular Pulley System, Open Air Intake, BillBoost Tune, TransGo SKĀ® 4T65E Transmission Shift Kit, 180* Thermostat
  1. code 0442 Evap system 2001 3.8L
    By chumley in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 04-11-2013, 12:57 PM
  2. Need Help With Evap system engine code P1665
    By josh22 in forum Introductions/Noob Questions
    Last Post: 01-18-2013, 10:53 PM
  3. Evap system leak in '06 GXP
    By GPGXP06 in forum 5.3L V8 (LS4)
    Last Post: 06-13-2012, 10:30 AM
  4. Deleting EVAP System
    By blueguy in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 06-16-2010, 01:48 PM
  5. Problem with the EVAP system
    By victorrleo in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-15-2009, 06:10 AM
