Thread: Name that noise!!
Page 2 of 2 FirstFirst 12
Results 21 to 27 of 27
  1. #21 Re: Name that noise!!
    May 2008
    Schuyler, NE
    Here is what mine sounded liked when the flexplate to crank bolts backed out.
    http://youtu.be/3_5uUBg9AOg?list=UUV...nozNP65AEyCh5Q
  2. #22 Re: Name that noise!!
    May 2008
    Schuyler, NE
  3. #23 Re: Name that noise!!
    Thanks!!! car goes back on the lift tomorrow and thats exactly what ill be checking.
    sure seems like thats the problem! so it may not be a cracked flex but the convertor bolt holes get stretched or egg shaped or what? seems like that vid still has bolt holding it but the flex obviously has a lot of play. you happen to have pics of the trashed flex plate??
  4. #24 Re: Name that noise!!
    that first vid has alot of intake noise but certianly sounds like mine!
  5. #25 Re: Name that noise!!
    May 2008
    Schuyler, NE
    Quote Originally Posted by 98ChainStretcher View Post
    I had the convertor bolts loose because I was getting ready to pull the motor again. The problem was the bolts that hold the flex plate to the crank backed out. The flex plate was loose and flopping around on the crank.
  6. #26 Re: Name that noise!!
    Ooopsie.. I've had loose TC bolts. They sound just like you'd think a loose TC bolt would sound. I think Tyler cracked his flex.
  7. #27 Re: Name that noise!!
    Tyler.. stop playing with it in the vid and fix it!
  1. Got a new noise. Might be transmission noise vid included.
    By buickman104 in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 07-02-2012, 05:51 PM
  2. Another f...in noise!
    By RyanL in forum Brakes/Suspension/Chassis
    Last Post: 10-11-2010, 02:47 PM
  3. Odd Noise
    By tdaye in forum General Tech Discussion
    Last Post: 06-19-2009, 07:57 AM
  4. This noise
    By pontiackid in forum General Tech Discussion
    Last Post: 06-11-2009, 11:41 AM
  5. Noise help
    By GMPUNK in forum General Tech Discussion
    Last Post: 02-08-2009, 05:07 AM
