Thread: Another E85 question
Page 2 of 2 FirstFirst 12
Results 21 to 28 of 28
  1. #21 Re: Another E85 question
  2. #22 Re: Another E85 question
    Mar 2014
    Tucson
    Quote Originally Posted by 98ChainStretcher View Post
    Are you people insane?
    Speaking only for myself... Maybe a little!
    Just easier to lean against a gas can while it's pouring into my car, than breaking out any wrenches. To each his own though.
  3. #23 Re: Another E85 question
    Ive swapped back and forth 3 times now since having the setup once was in the gas station parking lot just moved to the side of the lot, once was in my parking ramp, and the other was in a pep boys parking lot.
    If you cannot make a round trip on e85 this is hands down the way to go IMO. No hassle at all leave town on E85 when you need to fill up with regular gas swap pcms at the same time.
    Of course only easier solution is to bring along a laptop and flash the pcm.......
  4. #24 Re: Another E85 question
    Dec 2010
    DMV
    Both methods are quick. Question though, I have a tuned pcm from reptile so it's not a stock pcm so can I still run the 42lb injectors with no problems
  5. #25 Re: Another E85 question
    Feb 2009
    flintnasty MI
    Quote Originally Posted by 91parkave View Post
    Better make sure that gasoline tank is air tight. E85 absorbs moisture fairly quickly.
    it absorbs water from the air at the same rate as regular fuel does.
  6. #26 Re: Another E85 question
    hangover park IL
    but it can absorb a far larger volume of water than regular fuel. so long term storage of e85 does present a problem if not sealed. which means more headaches as you fill yer tank from the cans and then fill the cans with fresh e85 to keep cycling yer fuel stock...
    btw its two 7mm bolts for the pcm connectors.
    ~James~ Psychotic Gearhead
  7. #27 Re: Another E85 question
    8mm for battery then..... Meh both sizes are in the shoe box lol
  8. #28 Re: Another E85 question
    Arizona
    No..
  1. To mod, or to rebuild? That is the question.. The $2000 question
    By comatoast in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-15-2013, 07:16 PM
  2. brake part question not completely noob question!!
    By Lastremanent in forum Introductions/Noob Questions
    Last Post: 06-11-2013, 05:18 AM
  3. stupid question, dont mind me.(CAI question)
    By Silversurfer Gio in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 05-20-2012, 10:40 AM
  4. FWI(fender well intake) question. Exhaust(cat) question.
    By DJspinner in forum General Tech Discussion
    Last Post: 01-23-2010, 01:47 AM
  5. Vacume Tree question & Pcv question
    By 99prixgt in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-24-2009, 01:14 AM
