Are you people insane? It takes me less time to swap pcm's than it does to fill the gas tank! Cmon its 2 8mm bolts......
throw pcm in, throw smaller pulley on with shorted belt that's instant 60 WHP on my car!
takes a fist full of tools. I use a 15 mm wrench and a 17mm wrench to get the belt off (if you can figure out how to setup 2 wrenches for leverage, stick to driving a prius!) no ratchet/breaker bar needed here! plus an allen wrench for the sc hub, and a 1/4" drive with a 8mm socket for the pcm. My pcm is in a tray so it snaps down in the holder.
You guys are making this way over complicated screw carrying around fuel!
Id swap pcm's every day all day over carrying around fuel in the trunk screw that noise plus its added weight!.... NO thanks!
