but it can absorb a far larger volume of water than regular fuel. so long term storage of e85 does present a problem if not sealed. which means more headaches as you fill yer tank from the cans and then fill the cans with fresh e85 to keep cycling yer fuel stock...
btw its two 7mm bolts for the pcm connectors.
