Thread: questions about Swapping in l36 pistons into my l67!
Results 1 to 3 of 3
  1. #1 questions about Swapping in l36 pistons into my l67!
    Jul 2014
    Virginia
    Looking to see if this is a good idea and how much power itll net me!
    Mods include 2.25 intercooler stage 2 cam stage 3 heads 3.0 pulley. Full exhaust upgrade. Thanks!
  2. #2 Re: questions about Swapping in l36 pistons into my l67!
    St. Louis
    Depends on what you are going for. Sure, it would bump the compression a bit. Doing this sounds like a top swap to me. N/A bottom end w/ supercharged top. You would have to tune it and also have the proper machine work done to the bottom end to reassemble everything correctly and make it last more than 100 mi. If you really want to do this I would think finding a used N/A motor and swapping your parts onto it would be better and cheaper option, so as not to disturb the stock bottom end. Just my .02
    If you are looking for more power then you could go to a Gen V blower if you haven't already. More efficient blower. Probably wouldn't need that 3.0 pulley on it. Or you could sell it all and go turbo and make even better power.
  3. #3 Re: questions about Swapping in l36 pistons into my l67!
    L67 is better, don't touch the bottom end.
  1. Swapping Gen v have some questions
    By jayroca in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 09-11-2013, 12:52 AM
  2. Questions about top swapping and a non-HD trans
    By gtcoup in forum General Tech Discussion
    Last Post: 08-21-2011, 08:43 PM
  3. swapping cases have a few questions.
    By justin1795 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-10-2011, 09:57 PM
  4. Top Swapping I have questions.
    By GAFF in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-30-2010, 10:17 AM
  5. Questions on swapping parts
    By mscally07 in forum Audio, Security & Visual Electronics
    Last Post: 08-07-2009, 12:59 AM
