Thread: Swapping Gen v have some questions
Results 1 to 13 of 13
  1. #1 Swapping Gen v have some questions
    Banned
    Jan 2013
    maryland
    Ok guys I'm gonna swap my Gen V Into my current setup and I have some questions oh and I have read the write up for it very informative. Would I really need to get a altenator bracket from a 98 up grand prix? Could I just shave off some of the bracket? And if so what did you guys use to trim it with im not around a dremel so im teyna improvise if I do the n* lq4 combo would I need a tune after the install? Thanks
    Sent from my SAMSUNG-SGH-I747 using Tapatalk 2
  2. #2 Re: Swapping Gen v have some questions
    Just get a TB adapter plate, that why you arent swapping TB's and you'll need no tune.
  3. #3 Re: Swapping Gen v have some questions
    Banned
    Jan 2013
    maryland
    Thanks I'll look into that but for now could I just swap with n* lq4 and tune a little after the swap? Being as I will actually want that setup after its all said and done to go with my cam intercooler ported head setup
  4. #4 Re: Swapping Gen v have some questions
    Mercer, Pa
    The bolt pattern for the throttle body is different on a gen 5 than a gen 3 so nothing will bolt up. You have to buy an adapter so buy the adapter for what your planning on running. If you change to a different style of throttle body you need a tune.
  5. #5 Re: Swapping Gen v have some questions
    Banned
    Jan 2013
    maryland
    Quote Originally Posted by sseilmnop View Post
    I have a gen 5 to n* adapter plate
  6. #6 Re: Swapping Gen v have some questions
    Mercer, Pa
    Your asking if you change to the n* even though its not tuned for it will it run? Maybe, probable not well.
  7. #7 Re: Swapping Gen v have some questions
    GTP Level Member GTP89's Avatar
    Buena Park Ca
    If you plan to pulley drop and intercool do a one time tune no need to do different tunes as you add that is what I did. Put cam gen v, injectors, N* and had it all tuned to it.
    If You Cant Hear The Whine You're Too Far Behind...
  8. #8 Re: Swapping Gen v have some questions
    Feb 2013
    Missouri
    Don't forget you'll have to cut out your l67 LIM, the outlet on the Gen V is bigger.
  9. #9 Re: Swapping Gen v have some questions
    Banned
    Jan 2013
    maryland
    Quote Originally Posted by Booba5185 View Post
    Like this?
  10. #10 Re: Swapping Gen v have some questions
    Jan 2012
    Philadelphia
    You don't need to change your alt bracket unless you plan on running an IC if you have a 97 or 98 you will need a 99+ alt and bracket
  11. #11 Re: Swapping Gen v have some questions
    GTP Level Member 231FUN's Avatar
    Dec 2011
    Ontario,Canada
    Use the Gen V gasket as a template, It will show you how the L67 LIM needs to be cut to fit the Gen V to it.
  12. #12 Re: Swapping Gen v have some questions
    Mercer, Pa
    LIM modification is not required but can improve air flow. Modify to match your intercooler. Lot of gen 3 intercoolers under gen 5 supercharges. If you run a gen 3 intercooler no need to make this bigger than the intercooler.
  13. #13 Re: Swapping Gen v have some questions
    Feb 2013
    Missouri
    Hard to tell from the pic, but here's another pic, with the Gen V gasket:
  1. 98 GTP swapping non S/C 3.8
    By brktracer in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 01-02-2013, 09:07 AM
  2. Questions about top swapping and a non-HD trans
    By gtcoup in forum General Tech Discussion
    Last Post: 08-21-2011, 08:43 PM
  3. swapping cases have a few questions.
    By justin1795 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 03-10-2011, 09:57 PM
  4. Top Swapping I have questions.
    By GAFF in forum 3.8L V6 Naturally Aspirated (L36)(L26)
    Last Post: 06-30-2010, 10:17 AM
  5. Questions on swapping parts
    By mscally07 in forum Audio, Security & Visual Electronics
    Last Post: 08-07-2009, 12:59 AM
