Thread: compression test question
Results 1 to 12 of 12
  1. #1 compression test question
    GT Level Member kking89's Avatar
    st.louis
    Recently picked up a SC 3800 series 3 from an 06 GP for only 89 bucks. Need to do a compression test on it. What should be the psi rating for each cylinder? So I know if the motor is shot or not
  2. #2 Re: compression test question
    170 ish would be nice to see.
    if the engine is out of the car pull all of the plugs, then jump the starter with jumper cables to crank the engine over.
    if its still in the car at the yard you can do the same. just need a battery and jumper cables.
  3. #3 Re: compression test question
    st.louis
    It's in my garage. Sc has no play. Valve cover gaskets for sure need replacing. But is there a range of psi that would be acceptable. Like for example 130-200 or whatever. I'm just throwing out numbers.
  4. #4 Re: compression test question
    yes, in the 170 range, they all more then likely wont be the same, one may be 165, the next 173 and so on.
    as long as they are all close to the same psi rage its ok.
    if you get one thats like 135 you know theres a issue.
  5. #5 Re: compression test question
    st.louis
    So basically if every cylinder is like either 10 pounds Higher or lower then 10 I'm alright so like 160-180. Anything else there's problems
  6. #6 Re: compression test question
  7. #7 Re: compression test question
    Blocked open TB.. I've almost always seen 180 psi give or take 5%
  8. #8 Re: compression test question
    st.louis
    Or basically are u saying as long as each cylinder reads close to each other then it should be fine
  9. #9 Re: compression test question
    That's exactly what his long winded speech said.
  10. #10 Re: compression test question
    st.louis
    Well I need to know gm specific cylinder psi rating. And I know the lowest cylinder has to be like within 10% of the highest cylinder
  11. #11 Re: compression test question
    You are spending way too much time and effort on this.
    I've never checked an engine before installing. Unless I heard it run in a car. So far.. lucky..only one bad one after 20 miles.
  12. #12 Re: compression test question
    key thing is that they all test about the same.
    one piston may have more oil in it or something and that will cause higher psi too. say the engine was on its side, those 3 pistons would have been oil soaked some.
  1. Compression test results?
    By Jcinstalls in forum 3.1L V6 (LHO/LG8)
    Last Post: 04-05-2015, 10:58 AM
  2. Compression test results
    By Nickell in forum General Tech Discussion
    Last Post: 12-02-2013, 08:23 PM
  3. Compression test procedure?
    By Elite6 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 08-08-2013, 09:42 PM
  4. Did a compression test today...
    By Iron Indian in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-03-2009, 09:37 AM
  5. Compression Test
    By RedGrandPrix in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-28-2009, 10:38 PM
