Quote Originally Posted by JayHerlth View Post
It once upon was tucked back there, until I noticed it wasn't on the bracket and tugged on the loose line. Only to find tape on the end.
That would also explain my wot issue. Was getting a p0101 and p0102 error. Thought my maf was bad and causing it. Cleaned it, and still nothing. At around 4k rpm it just doesn't want to go past it.
the line with blue tape should run down the pass side fender and under the fuse box then into the wire harness and into the cars cab. it controls the air flow direction of the a/c and heat. i bet that stuff dont work, stuck on floor and defrost right?
you can buy them T's at advance auto.
