Thread: Found a random taped off vacuum line, help please?
Results 21 to 40 of 46
  1. #1 Re: Found a random taped off vacuum line, help please?
    Jan 2014
    AR
    Loog loob lol
  2. #2 Re: Found a random taped off vacuum line, help please?
    The fitting in the LIM is 1/4" iirc and the others are 1/8"
  3. #3 Re: Found a random taped off vacuum line, help please?
    Jun 2014
    Maryland, USA
    Thank you, will save a bit of time on my side.
  4. #4 Re: Found a random taped off vacuum line, help please?
    been there, minus the driving the parents car, they never let me use their cars, if i wanted to drive a car i had to buy it myself, insure it myself, pay to fix it, gas it up, every damn thing, zero help at all. you want it,,,,you will pay for it yourself i was told, and they meant it. trust me lol
    i used a lot of junk yard parts as a kid. you do what you gotta do.
    my father pretty much sold me his 77 gmc, ( i was still paying it off) the clutch went bad and it was dead in the water, so i pulled the engine out and changed the clutch. i know trans out seems like the way to go but it was a 4 speed manual and it was heavy and i had no trans jack.
    my dad pulls in the drive way as the engine is just coming up and over the rad support, all he does is look at wtf is going on, then says that had best run again lol and walked away. next day it was on the road again.
    luck for me this was not my first engine pull at home, so they had seen one come out one go back in and it drive away a few times.
  5. #5 Re: Found a random taped off vacuum line, help please?
    Jun 2014
    Maryland, USA
    I've got a gravel driveway and no tools to lift one out. If I did, I would be doing so much more to this car (given if I had the money.) anywho, I still have to jack it up and replace two rear struts in a gravel driveway. Then figure out why all of my windows are shot. Found a missing cable to the master switch on drivers door. Junk yard it will have to be for that. Or wire my own.
  6. #6 Re: Found a random taped off vacuum line, help please?
    Jun 2014
    Maryland, USA
    Real quick, since you're actively replying and this is a Grand Prix forums. What does that little button on the shift stick do? Have found no info and am too scared to drive around and press it. Lol
  7. #7 Re: Found a random taped off vacuum line, help please?
    Quote Originally Posted by JayHerlth View Post
    push it, its fun lol
    its the performance shift button, push the button and a light on the dash or dic will say "perf shift" when its lit up its in that mode, this will make the shifts points a bit further up the rpm range, and make it shift better, faster/firmer.
  8. #8 Re: Found a random taped off vacuum line, help please?
    Jun 2014
    Maryland, USA
    I like that response "push it, its fun lol"
    I will be sure to do that when I replace the rear struts and fix that t connector. Was amazed it ran me ten miles with that missing... At least I'm now aware that it's a reliable engine
  9. #9 Re: Found a random taped off vacuum line, help please?
    these engines can take a good beating, just keep up with your oil changes and regular maintenance. not that im saying to beat the tar out of it all day long lol quite reliable most of the time. like any car tho, its got it common issues that pop up.
  10. #10 Re: Found a random taped off vacuum line, help please?
    Jun 2014
    Maryland, USA
    Like a missing vacuum connector.. Anywho, I'm waiting till Friday for my struts to come in the mail. Tomorrow afternoon I'll definitely be heading up to the local store and finding some fittings and tubing to make one of my own. Get an oil filter, and flush the coolant system. I've got fuel system cleaner just for general purposes, need to wait till it's titled and on the road first before I can actually fill it up 100% in order to do that. Now my biggest issue will be getting the windows to work... Do you believe that a few wires disconnected from the master switch will affect all windows including sun roof? Fuse is absolutely fine, just don't know if I really need to go through the trouble of troubleshooting every last window and motor.
  11. #11 Re: Found a random taped off vacuum line, help please?
    take the door skins off the inside of the doors, with a test light see if the plug to the motors getting power when the switch is worked.
    a bad master switch will make the windows not work. mine the child lock part took a dump and only the master switch could work any of the windows.
  12. #12 Re: Found a random taped off vacuum line, help please?
    Jun 2014
    Maryland, USA
    I just need a single window working from drivers seat. We have a family friend that will inspect it and pass it as long as we have a working window, simply because of safety issues. Door gets stuck somehow (don't ask me how I could get locked into the car) but if I need a way out, or whatever the reason be. I'll need to hit up some junkyards. Hoping they have a grand prix. If anything I'm just going to get some auto wire at the local shop, and have fun re-making the torn part of the harness...
    I haven't seen any door harnesses being sold online. All I can imagine being able to do is ripping one out of an old wrecked grand prix at a yard or something.
  13. #13 Re: Found a random taped off vacuum line, help please?
    you can patch broken wires easy. get yourself a soldering iron, shrink tubes and solder. done deal.
    always strip the ends back till you hit clean shinny copper, then solder.
  14. #14 Re: Found a random taped off vacuum line, help please?
    Jun 2014
    Maryland, USA
    Had to do that once or twice with some RC planes/helicopters.. When you wreck it, some wire likes to decide to tear.
    My only concern would be plugging it into the actual harness. I really don't want to go at it with 10lbs of electrical tape holding it all into the socket.
    Any tips or ideas as to how I could approach that?
  15. #15 Re: Found a random taped off vacuum line, help please?
    you dont have to replace it all, leave 4 inches off the plus ends, solder to that, or you push the pins out, and then you need to find new pins to crimp and solder on the wires to fit the plugs.
    leaving a pig tail is easier.
    if you do find a broken wire chances are it will be inside the rubber accordion part door to body.
    then theres always the chance all 4 window motors took a crap. if you have some wire you can run a wire from the battery to the motor, you'll need a ground too, then touch the terminals on the motor. it should work if it works. switching the wires around should make it move the opposite way.
    if they work with direct power you have a switch or wire problem.
  16. #16 Re: Found a random taped off vacuum line, help please?
    Jun 2014
    Maryland, USA
    Well, my issue is that the plug is actually missing (for front two windows) the rear window switch plug is in place. I'm not too sure why exactly it was ripped out?.. My issues with buying used, there's some weird shiz you will find that you just will never find the answer to..
  17. #17 Re: Found a random taped off vacuum line, help please?
    in that case, you can buy a new pig tail, thats a plug and 12 inches of wire off it. one for each window. theres a shop on e bay that will make any GM pig tail you need brand new properly color coded too.
    you can pm them during the week, they responded very fast to me. as all they list is ls1 stuff. but can make any thing GM for like 10 bucks a pig tail. http://www.ebay.com/sch/autowiringso..._from=&_ipg=25
    or if you have local junk yard cut the plugs off and solder them to your wires. the wires are colored and should be the same. easy to match up.
  18. #18 Re: Found a random taped off vacuum line, help please?
    I'd hit up the JY and get a new door harness. I did this to get some wiring to add into my car. They unplug right in the A pillar of the car and then after you unplug the various parts in the door..it pops out decently.
  19. #19 Re: Found a random taped off vacuum line, help please?
    Jun 2014
    Maryland, USA
    Replaced both rear struts, the ride is much smoother. Found a universal t connector (pretty cool) so it fit but is a bit large for the connection so looks a little odd. Still waiting for the connector to come in the mail.
    The errors are all gone, due to the little MAP connector. And next project is getting the AC to blast and windows diagnosed/working.
  20. #20 Re: Found a random taped off vacuum line, help please?
    for the vents to work you need to find the other side of the tapped off line, under the fuse box, or on the fender .
  1. Vacuum Line
    By sumdude in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 07-02-2011, 03:05 PM
  2. Random thought. Vacuum controlled Cutout?
    By benner in forum General Tech Discussion
    Last Post: 04-22-2011, 12:10 PM
  3. i need a vacuum line
    By boostedgtp13 in forum Off Topic Discussion
    Last Post: 04-20-2010, 09:07 PM
  4. vacuum line kit for 98 gtp?
    By Liquifire in forum General Tech Discussion
    Last Post: 11-09-2009, 09:49 AM
  5. Vacuum line
    By drewz313 in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 10-25-2009, 02:11 PM
