I tried the pipe and leverage thing on a car when impact wasn't available, failed. If things are still hooked up.. I'm all about the starter trick. Just be careful because you can get hurt.
Unhook the 7mm bolt holding the coil pack connector to the ICM. That will disable the motor from actually starting.
Ok I took the Icm off bill still no go.. one I my buddies said use the jack with rope on the breaker bar trick anybody heard of that?
Sent from my SAMSUNG-SGH-I747 using Tapatalk
