Thread: Best way to get the cam out the car with the engine bolted up
Page 2 of 2 FirstFirst 12
Results 21 to 30 of 30
  1. #21 Re: Best way to get the cam out the car with the engine bolted up
    ^lots of loctite was a ***** to get mine off from the factory ended up having this mobile mechanic come by with a 100 gallon air compressor and torching it to break the bolt loose.
    04 Comp G.
  2. #22 Re: Best way to get the cam out the car with the engine bolted up
    FIREFIGHTER/AEMT
    Dec 2013
    williamsport tennessee
    ive had real good luck with the starter trick....
    1998 grand prix gt 2 door
    2006 ram 2500 cummins diesel 4x4
    2015 NISSAN Rogue SL (wifes ride)
  3. #23 Re: Best way to get the cam out the car with the engine bolted up
    I tried the pipe and leverage thing on a car when impact wasn't available, failed. If things are still hooked up.. I'm all about the starter trick. Just be careful because you can get hurt.
    Unhook the 7mm bolt holding the coil pack connector to the ICM. That will disable the motor from actually starting.
  4. #24 Re: Best way to get the cam out the car with the engine bolted up
    Banned
    Jan 2013
    maryland
    Ok I took the Icm off bill still no go.. one I my buddies said use the jack with rope on the breaker bar trick anybody heard of that?
    Sent from my SAMSUNG-SGH-I747 using Tapatalk
  5. #25 Re: Best way to get the cam out the car with the engine bolted up
    Da fuq?
    Never heard of that unless he means use the jack pole on the end of the breaker bar
    04 Comp G.
  6. #26 Re: Best way to get the cam out the car with the engine bolted up
    No idea what he's talking about
  7. #27 Re: Best way to get the cam out the car with the engine bolted up
    Quote Originally Posted by jayroca View Post
    ive seen vids where people will rest the leverage end of the breaker bar on a jack stand, then crank the engine over. maybe hes talking about tying the bar to the jack stand so it cant jump off it?
  8. #28 Re: Best way to get the cam out the car with the engine bolted up
    Banned
    Jan 2013
    maryland
    Da fuq?
    Yes thats what he spoke of to better leverage
  9. #29 Re: Best way to get the cam out the car with the engine bolted up
    i used the floor jack handle all the time. i thought thats why it came off the jack all these years lol
  10. #30 Re: Best way to get the cam out the car with the engine bolted up
    I rest the bar on the subframe
  1. Replies: 10
    Last Post: 07-20-2021, 09:07 PM
  2. Replies: 15
    Last Post: 01-25-2013, 03:05 PM
  3. Check Engine Light - Wont downshift, whine coming from engine
    By brandibissell in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-11-2012, 08:17 AM
  4. Service Engine light flashes... engine shakes...hardly any power at all
    By bigbluegtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-08-2010, 07:10 PM
  5. Spartans Engine Swap (Engine Damage Pics on Front Page!)
    Last Post: 05-05-2010, 12:50 AM
