Thread: Best way to get the cam out the car with the engine bolted up
Results 1 to 20 of 30
  1. #1 Best way to get the cam out the car with the engine bolted up
    Banned
    Jan 2013
    maryland
    Ok gonna build another motor and im trying to get the cam out dropped the cradle and put the vice on the flexplate and breaker bar on the balancer dont have much leverage any tips should lower the cradle any lower? Get a pipe for better grip? Thanks?
    Sent from my SAMSUNG-SGH-I747 using Tapatalk
  2. #2 Re: Best way to get the cam out the car with the engine bolted up
    Vice grips on the flexplate, lower the cradle slightly and big ass breaker bar with a pipe and bam... Easy peazy
    04 Comp G.
  3. #3 Re: Best way to get the cam out the car with the engine bolted up
    Or you can do the old starter trick where you attach the breaker bar and socket on to the HB bolt and then have the handle of the breaker bar up against he subframe then crank it and when the starter engages it should loosen the bolt
    04 Comp G.
  4. #4 Re: Best way to get the cam out the car with the engine bolted up
    Banned
    Jan 2013
    maryland
    Like this red Compg or do I need to get a bigger one
  5. #5 Re: Best way to get the cam out the car with the engine bolted up
    That should be fine. When in doubt grab a pipe and throw it on the end of it.
    04 Comp G.
  6. #6 Re: Best way to get the cam out the car with the engine bolted up
    GTP Level Member WhiteLightningGTP's Avatar
    Nov 2012
    Frankenmuth, MI
    Aren't you going to have to take the engine out anyway to put the new one in?
    2004 Comp G "The Panda"- low, e85, big brakes SOLD
    2002 Trans Am- 6 speed, bolt ons or something, it's slow.
    2006 Silverado- forged ls2, 4l80e, plate kit, also slow...
  7. #7 Re: Best way to get the cam out the car with the engine bolted up
    pipe on the end for the win
  8. #8 Best way to get the cam out the car with the engine bolted up
    Nope this one has bottom end problems.. He's swapping the top half into the new car with the ok engine
    04 Comp G.
  9. #9 Re: Best way to get the cam out the car with the engine bolted up
    GTP Level Member BlackGT97's Avatar
    Jul 2011
    Michigan
    I usually hit the head of the bolt with a little heat abd it loosens right up.
    1997 Grand prix GT Black Coupe- The beater
    1998 Grand prix GT Black coupe- Top swapped, XP cam
    2008 Grand prix Midnight blue- The slow but nice car
    1999 Chevrolet Silverado red ext. Cab
  10. #10 Re: Best way to get the cam out the car with the engine bolted up
    Oct 2011
    Puyallup WA
    I put like a 4 foot pipe on my breaker bar and my buddy held flywheel with big prybar
    08 G8 GT - exhaust Tune
  11. #11 Re: Best way to get the cam out the car with the engine bolted up
    Both cars have blown engines and without impact this isn't going to be fun no matter how you look at it.
  12. #12 Re: Best way to get the cam out the car with the engine bolted up
    Banned
    Jan 2013
    maryland
    Ok guys im using the breaker bar with the 5inch pipe still no go even with screenplay on blaster no movement ... wish I didnt work out today at the gym smh lol any more suggestions? Any more ways to put more weight to loosen?
  13. #13 Re: Best way to get the cam out the car with the engine bolted up
    Torch it just don't burn the car down.
    04 Comp G.
  14. #14 Re: Best way to get the cam out the car with the engine bolted up
    Banned
    Jan 2013
    maryland
    No torch right now... no other option?
  15. #15 Re: Best way to get the cam out the car with the engine bolted up
    GTP Level Member 231FUN's Avatar
    Dec 2011
    Ontario,Canada
    Longer pipe...leverage is your friend
  16. #16 Re: Best way to get the cam out the car with the engine bolted up
    Quote Originally Posted by 231FUN View Post
    This. Next best move
    04 Comp G.
  17. #17 Re: Best way to get the cam out the car with the engine bolted up
    Banned
    Jan 2013
    maryland
    I'll try that 10 inch pipe
  18. #18 Re: Best way to get the cam out the car with the engine bolted up
    Quote Originally Posted by jayroca View Post
    No homo
    04 Comp G.
  19. #19 Re: Best way to get the cam out the car with the engine bolted up
    Banned
    Jan 2013
    maryland
    No homo
    Lol haha no homo
  20. #20 Re: Best way to get the cam out the car with the engine bolted up
    GT Level Member TwiztdWun's Avatar
    Feb 2013
    Ohio
    I recently pulled the balancer off mine when I swapped the engine out. It took a 1" impact gun to do it. They use a sealer similar/probably exactly the same on the threads to what they seal the snout of the supercharger.
    Official GPF Red Neck
  1. Replies: 10
    Last Post: 07-20-2021, 09:07 PM
  2. Replies: 15
    Last Post: 01-25-2013, 03:05 PM
  3. Check Engine Light - Wont downshift, whine coming from engine
    By brandibissell in forum 1997-2007 4 speed Automatic (4T65E) (4T65E-HD)
    Last Post: 01-11-2012, 08:17 AM
  4. Service Engine light flashes... engine shakes...hardly any power at all
    By bigbluegtp in forum 3.8L V6 Supercharged (L67)(L32)
    Last Post: 12-08-2010, 07:10 PM
  5. Spartans Engine Swap (Engine Damage Pics on Front Page!)
    Last Post: 05-05-2010, 12:50 AM
